You can setup a default Vizard environment by configuring the vizcore.cfg file. This allows you to set the default resolution, window dimensions, GUI color theme, default camera navigation handler, and more. To set these default values, create a vizcore.cfg file in Vizards bin directory. Then add the configuration options you are interested in by following the example vizcore.cfg file below. If there is a vizcore.cfg file in the same directory as the script, Vizard will load this as well. If the same option is specified in both the global and local vizcore.cfg file, the local copy will take precedence.
You can also dynamically set and read options in your script using the viz.setOption(name,value) and viz.getOption(name[,default]) commands.
The viz.setOption() command will set the value of the specified option name. If the option does not exist, it will be created, otherwise it will override the existing value. If the value is None then the option will be removed.
#Set the AVI recorder to record at 29.97
frames per seconds
viz.setOption('viz.AVIRecorder.fps','29.97')
The viz.getOption() command will return the string value of the specified option name. If the option does not exist, the specified default value will be returned.
#Print the Vizard version number
print viz.getOption('viz.version')
Here is a sample vizcore.cfg file that will perform the following for all scripts:
Set fullscreen anti-aliasing to 4x
Set fullscreen mode
Set background color to gray
viz.antialias = 4
# Lines beginning with the '#' symbol will be treated as comments
viz.fullscreen = 1
viz.clearcolor = 0.5 0.5 0.5
Usage restrictions: These options must be set before viz.go() is called.
Name |
Description |
Default value |
viz.antialias |
Specifies the full screen anti-alias sample number |
0 |
viz.window.width |
Initial non-fullscreen width of the window |
800 |
viz.window.height |
Initial non-fullscreen height of the window |
600 |
viz.window.x |
Initial x position of non-fullscreen window. Relative to upper left corner. |
0 |
viz.window.y |
Initial y position of non-fullscreen window. Relative to upper left corner. |
0 |
viz.window.icon |
Name of .ico file to use as icon for graphics window and published EXE. |
viz.window.visible |
Controls the visibility of the graphics window |
1 |
viz.display.width |
Resolution width of monitor to run Vizard simulation in |
0 |
viz.display.height |
Resolution height of monitor to run Vizard simulation in |
0 |
viz.display.color |
Color resolution of monitor to run Vizard simulation in |
0 |
viz.display.frequency |
Monitor refresh rate to run Vizard in |
0 |
viz.display.alpha |
Number of alpha bits to request when creating OpenGL context |
0 |
viz.display.stencil |
Number of stencil bits to request when creating OpenGL context |
0 |
viz.display.swap_copy |
When swapping buffers, copy contents of back buffer into front buffer, instead of exchanging contents (default). |
0 |
viz.display.gpu_affinity |
Enable/Disable nVidia GPU affinity option. If enabled and supported by your graphics driver, all rendering will be performed on the GPU associated with the monitor the graphics window is initially created on. |
0 |
viz.hmd |
Initialize in HMD mode |
0 |
viz.fullscreen |
Initialize in fullscreen mode |
0 |
viz.fullscreen.monitor |
The monitor to use for fullscreen operations. If 0, the entire combined monitor region will be used for fullscreen. |
0 |
viz.fullscreen.width |
The width to use for fullscreen mode. If 0, the monitor width will be used. |
0 |
viz.fullscreen.height |
The height to use for fullscreen mode. If 0, the monitor height will be used. |
0 |
viz.fullscreen.x |
The x position to use for fullscreen mode. Relative to upper left corner. |
0 |
viz.fullscreen.y |
The y position to use for fullscreen mode. Relative to upper left corner. |
0 |
viz.prompt |
Initialize with prompt window |
0 |
viz.stereo |
Default stereo mode if none is specified with viz.go() |
0 |
viz.quadbuffer |
Initialize in quad buffer stereo mode |
0 |
viz.stencil |
Initialize with stencil buffer |
0 |
Usage restrictions: These options must be set in vizcore.cfg file, before the script is executed.
viz.theme.border |
Theme border color |
0.25 0.35 0.45 1.0 |
viz.theme.text |
Theme text color |
1.0 1.0 1.0 1.0 |
viz.theme.back |
Theme background color |
0.58 0.68 0.78 1.0 |
viz.theme.lightBack |
Theme light background color |
0.68 0.75 0.83 1.0 |
viz.theme.darkBack |
Theme dark background color |
0.25 0.44 0.64 1.0 |
viz.theme.highBack |
Theme highlight background color |
viz.theme.highText |
Theme highlight text color |
1.0 0.78 0.34 1.0 |
viz.theme.check.down |
Checkbox check texture |
checkbox_down.gif |
viz.theme.check.up |
Checkbox uncheck texture |
checkbox_up.gif |
viz.theme.button.down |
Button down texture |
button_down_blue.gif |
viz.theme.button.up |
Button up texture |
button_up_blue.gif |
viz.theme.radio.down |
Radio selected texture |
radio_down.gif |
viz.theme.radio.up |
Radio unselected texture |
radio_up.gif |
viz.theme.slider.bar |
Slider bar texture |
back.jpg |
viz.theme.slider.tick |
Slider tick texture |
tick.jpg |
viz.logLevel |
Output log level (LOG_ALWAYS, LOG_ERROR, LOG_WARN, LOG_NOTICE, LOG_INFO, LOG_DEBUG) |
LOG_NOTICE |
viz.resource.path |
Semi-colon delimited string of directories to add to resource path. |
viz.resource.loaderOption |
File loader option string |
viz.physics.engine |
The default physics engine to load on startup. |
physics_opal.dll |
viz.sound3d.engine |
The default sound 3d engine to load on startup. |
sound3d_dx.dll |
viz.vsync |
Vertical sync mode |
1 |
viz.ipd |
Stereo IPD value |
0.06 |
viz.fov |
Field of View and aspect ratio. If aspect ratio is negative then it will be automatically computed based on window size. |
40 -1 |
viz.clip |
Near/Far clip plane. If either value is negative, the clip planes will be automatically computed. |
-1 -1 |
viz.overlap |
Stereo overlap |
1.0 |
viz.screenDistance |
Screen distance value for stereo modes. |
1.0 |
viz.clearcolor |
Window clear color |
0 0 0 |
viz.stereoHUD |
Controls whether HUD objects are rendered in stereo. 0 or 1 |
1 |
viz.clearDepth |
Clear depth buffer when rendering screen objects. |
1 |
viz.specularTexture |
Enables/Disables specular highlights on all textured objects. |
0 |
viz.lightModel.localViewer |
Use local viewpoint for calculating specular highlights. Enabling this will fix problems with specular highlights not being consistent on CAVE edges. |
0 |
viz.lightModel.twoSided |
Enable/Disable two sided lighting calculations. |
0 |
viz.lightModel.ambient |
Set the global ambient color |
0.2 0.2 0.2 |
viz.text.encoding |
The encoding to use for text display. If AUTO, Vizard will check the script for a UTF8 BOM. ( AUTO, ASCII, UTF8) |
AUTO |
viz.text.font |
The default font to use when creating text objects. |
arial.ttf |
viz.text.bidirectional |
Controls whether text will support displaying bidirectional UTF-8 characters. |
0 |
viz.text.line_spacing |
The default line spacing to use when creating text objects. The spacing is specified as a percentage of the character height. |
0.0 |
viz.text.thickness |
The default thickness to use when creating 3D text objects. The thickness is specified as a percentage of the character height. |
0.1 |
viz.camera |
Name of camera handler class in the vizcam module (PivotNavigate, PanoramaNavigate, etc..) |
viz.network.buffer_size |
Size of buffer that will receive all network data. |
65536 |
viz.network.port |
Port used for sending/receiving network data. |
4950 |
viz.network.port_in |
Space delimited list of additional ports to receive network data on. |
viz.splashscreen |
Image file to use as a loading splash screen |
viz.mouse.visible |
Controls if the mouse cursor is visible. |
1 |
viz.mouse.trap |
Controls if the mouse cursor is trapped inside the Vizard graphics window. |
0 |
viz.mouse.sensitivity |
Mouse navigation sensitivity. |
1 1 |
viz.cluster.master.clients |
Space delimited list of clients to connect to in cluster. Cluster master application will take precedence over this option. |
viz.cluster.master.port |
Port to use for cluster communication. |
8501 |
viz.cluster.master.sync |
Enable/Disable synchronization of frames between cluster nodes. |
1 |
viz.cluster.master.sync_gpu |
Controls whether GPU processing is synchronized between cluster nodes. Only used if frame synchronization is also enabled. |
0 |
viz.cluster.master.transmit_mouse |
Enable/Disable transmitting mouse navigation to clients. |
1 |
viz.cluster.master.buffer_flush_size |
Number of bytes in cluster message buffer before sending to clients. |
4096 |
viz.cluster.master.broadcast_address |
The address to use for broadcasting sync signal to clients. |
255.255.255.255 |
viz.cluster.master.abortOnLostConnection |
Controls whether the cluster master will abort the simulation if the connection to a client is lost. |
1 |
viz.cluster.connect_timeout |
Timeout for connecting to master/clients (milliseconds) |
15000 |
viz.cluster.sync_timeout |
Timeout for syncing frame with other machines (milliseconds) |
10000 |
viz.cluster.frame_timeout |
Timeout for sending/receiving messages for a frame (milliseconds) |
20000 |
python.optimize |
Set the optimize flag to initialize the Python interpreter with. Can be one of the following values: 0 - No optimization (default value) 1 - Equivalent to -O option, ignores assert statements 2 - Equivalent to -OO option, doc strings will not be included in compiled pyo files. |
0 |
Usage restrictions: These options must be set before the associated commands are executed.
viz.default_key.quit |
Enable/Disable default key for quitting Vizard script |
1 |
viz.default_key.display_html |
Enable/Disable default key for toggling display of html help |
1 |
viz.default_key.fullscreen |
Enable/Disable default key for toggling fullscreen mode |
1 |
viz.default_key.poly_mode |
Enable/Disable default key for toggling through polygon mode |
1 |
viz.default_key.framerate |
Enable/Disable default key for toggling framerate display |
1 |
viz.default_key.camera_reset |
Enable/Disable default key for resetting camera handler |
1 |
viz.default_key.capture_image |
Enable/Disable default key for capturing screen to an image |
1 |
viz.default_key.capture_video |
Enable/Disable default key for recording screen to a video |
1 |
viz.default_key.dock_window |
Enable/Disable default key for toggling docking of script window within IDE |
1 |
viz.default_key.interactive |
Enable/Disable default key for activating interactive window of IDE |
1 |
viz.AVIRecorder.maxWidth |
Maximum width for recording AVI |
640 |
viz.AVIRecorder.maxHeight |
Maximum height for recording AVI |
480 |
viz.AVIRecorder.fps |
Frame rate for recording AVI |
30 |
viz.AVIRecorder.drawCursor |
Capture mouse cursor in AVI |
0 |
viz.check_gl_errors |
Controls whether Vizard performs fine grained OpenGL error checking. |
0 |
viz.glFinish |
Controls whether Vizard synchronizes with the GPU after swapping the frame buffer by calling glFinish(). |
0 |
viz.dwm_composition |
Controls whether Desktop Window Manager (DWM) composition is allowed while the script is running. |
1 |
viz.preload |
Tells Vizard if it should preload all objects to the graphics card before rendering the first frame. |
1 |
viz.hint |
A combination of hint flags to apply on all the scenes before the first frame is rendered. |
0 |
viz.node.op_mode |
Specifies the default op mode to use when a node is created. Can be a combination of the following values: 4 - OP_TRAVERSE 8 - OP_OVERRIDE 16 - OP_ROOT |
4 |
viz.model.optimize |
Automatically optimize models after they are loaded. |
0 |
viz.model.hint |
A combination of hint flags to apply to all loaded models. |
0 |
viz.model.cache |
The default cache mode to use. Can be one of the following values: 0 - viz.CACHE_NONE 1 - viz.CACHE_COPY 2 - viz.CACHE_CLONE |
0 |
viz.model.apply_collada_scale |
Automatically apply embedded meter scale factor to loaded Collada models. |
0 |
viz.texture.share |
Tells Vizard if it should share the textures of a model after it is loaded. This helps save texture memory when loading models that reference the same image file. |
1 |
viz.texture.hint |
A combination of hint flags to apply to textures created with viz.addTexture command. Will not be applied to render/blank textures. |
0 |
viznet.server.port |
The port viznet servers will communicate over. |
viz.NETWORK_PORT |
viznet.server.port_in |
The port for viznet servers to receive messages on. If not specified, it will inherit the value from the viznet.server.port option. |
viznet.server.port_out |
The port the viznet servers will send messages on. If not specified, it will inherit the value from the viznet.server.port option. |
viznet.client.port |
The port viznet clients will communicatye over. |
viz.NETWORK_PORT |
viznet.client.port_in |
The port for viznet clients to receive messages on. If not specified, it will inherit the value from the viznet.client.port option. |
viznet.client.port_out |
The port the viznet clients will send messages on. If not specified, it will inherit the value from the viznet.client.port option. |
hd.version |
Version of OpenHaptics plugin to use. Can be either 1 or 2. Must be set before hd module is imported. |
2 |
viz.shader.normal_map_unit |
The texture unit to use when generating tangent/binormal data for geometry. |
0 |
viz.shader.tangent.name |
The attribute name to use for tangent data. |
Tangent |
viz.shader.tangent.index |
The attribute index to use for tangent data. |
6 |
viz.shader.binormal.name |
The attribute name to use for binormal data. |
Binormal |
viz.shader.binormal.index |
The attribute index to use for binormal data. |
7 |
viz.link.resetOriPriority |
The priority to use for link reset ori operators. |
-10 |
LiveCharacter.connectionWarnTimeout |
Print warning if LiveCharacter has not received response from server after this many seconds. |
2 |
LiveCharacter.connectionRetryTimeout |
Retry connecting to LiveCharacter server if have not received update after this many seconds. |
2 |
viz.publish.crc |
Controls whether published EXEs will perform CRC on the exe when running. Set to 0 if you need to disable the CRC check. |
1 |
viz.publish.load_message |
Message to display in popup box while publish EXE is loading. If set to an empty string, the popup box will not appear. |
Vizard launching, please wait... |
viz.publish.load_title |
Title of popup box while publish EXE is loading. The title appears in the taskbar. If set to an empty string, the popup box won't appear in the taskbar. |
Vizard launching |
viz.publish.persistent |
Controls whether the contents of the published EXE will persist on the users drive after being unpacked. If enabled, you must also specify a unique name for the viz.publish.product option. The files will persist in a directory based on the specified company/product names:
%TEMP%/<company>/<product>
When enabled, this option allows for much faster startup times of the published EXE, since it will only need to be unpacked once on the end users system, and subsequent executions will run form the existing directory. |
0 |
viz.publish.persist_folder |
The folder to unpack persistent EXEs to. Must begin with one of the following tags:
<temp> - Users temp folder <appdata> - Users application data folder |
<temp>/<company>/<product> |
viz.publish.product |
The product name to use for published EXEs |
viz.publish.company |
The company name to use for published EXEs |
WorldViz |
viz.prevent_screensaver |
Controls whether Vizard should prevent the screen saver from starting while the script is running. |
0 |
viz.max_frame_rate |
The maximum framerate to allow Vizard to run at. If 0, then Vizard will run as fast as possible. |
0 |
viz.html.allowEscape |
Controls whether the Escape key will close the HTML window when it as focus. |
1 |
sound3d.useViewRotation |
Controls whether the viewpoint rotation is used for spatializing the sound. |
1 |
sound3d.dx.algorithm |
The algorithm used by the DirectX 3D sound plugin. Can be one of the following string values:
NO_VIRTUALIZATION HRTF_FULL HRTF_LIGHT
If no value is specified, a default algorithm will be selected based on the user preference in the Control Panel. |
Usage restrictions: Read-only.
viz.version |
Current version of vizard |
NA |
viz.monitor.count |
Number of monitors |
NA |
viz.monitor.width |
Current width of monitor resolution. |
NA |
viz.monitor.height |
Current height of monitor resolution. |
NA |
viz.monitor.refresh_rate |
Current refresh rate of monitor |
NA |
viz.cluster |
1 if running in cluster mode, otherwise 0 |
NA |
viz.cluster.clients |
Number of clients, when running in cluster mode. |
NA |
viz.publish |
1 when running in published mode, otherwise 0. |
NA |
viz.publish.path |
The path of the published exe, when running in published mode. |
NA |
gl.extensions |
List of OpenGL extensions supported by graphics card. Extension names are separated with spaces. |
NA |
gl.version |
OpenGL version supported by driver |
NA |
gl.vendor |
OpenGL driver vendor. Typically maker of graphics card. |
NA |
gl.renderer |
OpenGL renderer. Typically name of graphics card.
NA |
gl.shading_language_version |
OpenGL shading language version |
NA |
gl.max_texture_size |
Maximum 2D texture dimension supported by driver |
NA |
gl.max_3d_texture_size |
Maximum 3D texture dimension supported by driver |
NA |
gl.max_cube_map_texture_size |
Maximum Cubemap texture dimension supported by driver |
NA |
gl.max_texture_units |
Maximum fixed function texture units supported by driver |
NA |
gl.max_texture_image_units |
Maximum fragment shader texture units supported by driver |
NA |
gl.max_vertex_texture_image_units |
Maximum vertex shader textures units supported by driver |
NA |
gl.max_combined_texture_image_units |
Maximum vertex and fragment shader texture units supported by driver |
NA |
gl.colorBits |
Color buffer bit depth of created window |
NA |
gl.redBits |
Red channel bit depth of created window |
NA |
gl.greenBits |
Green channel bit depth of created window |
NA |
gl.blueBits |
Blue channel bit depth of created window |
NA |
gl.alphaBits |
Alpha channel bit depth of created window |
NA |
gl.depthBits |
Depth buffer bit depth of created window |
NA |
gl.stencilBits |
Stencil buffer bit depth of created window |
NA |
gl.stereo |
1 if quad buffer stereo is supported by created window, otherwise 0 |
NA |
gl.pixelFormatIndex |
The selected pixel format index of the created window |
NA |
gl.multiSamples |
Multi sampling level of created window |
NA |
