Reference: GUIs
Making pop-downs with vizmenu
To create pop-down menus, use Vizard's vizmenu module and then fill those menus with any of Vizard's GUI elements (sliders, buttons, dropdown lists, text boxes, etc.). You can also nest pop-down menus within your main pop-downs to create expanding menus.  Here's the basic process for creating a pop-down menu:
#Create main menu object
import vizmenu
menu = vizmenu.add()
#Align the menu in the enter of the top of the screen.
menu.setAlignment( vizmenu.CENTER )
#Add two pop-downs menus within the main menu.
AppearanceMenu = menu.add( 'Appearance' )
Ball1Menu = menu.add( 'Ball 1' )
#Add a droplist to one of the pop-downs.
themeDropDown = AppearanceMenu.add( viz.DROPLIST, 'Theme' )
themeDropDown.addItems( ['Default','Dark','Green'] )
#Add sub-menu under the Ball1 menu and put radio buttons in it.
Ball1ColorMenu = Ball1Menu.add( vizmenu.MENU, 'Color' )
Ball1Red = Ball1ColorMenu.add( viz.RADIO, 0, 'Red' )
Ball1White = Ball1ColorMenu.add( viz.RADIO, 0, 'White' )
Ball1Blue = Ball1ColorMenu.add( viz.RADIO, 0, 'Blue' )
#Add another sub-menu to the Ball1 menu for a slider.
Ball1SizeSlider = Ball1Menu.add( viz.SLIDER, 'Size' )
To change the appearance of your pop-downs (the color theme, fonts, etc.), check out the section on GUI appearance. To learn how to get the user responses from the elements in the pop-down menu, check out the section on getting data from GUI elements.
See also
In this section:
User interface basics
GUI elements
Getting data from GUI elements
GUI appearance
vizinfo
vizmenu
vizinput
vizdlg
vizconfig
viztip
Displaying HTML
GUI command table
Other sections:
Event Basics
Action basics
Text node basics
Example scripts:
vizInfo
vizMenu
Prompt
