Vizard 7 » Reference » Input Devices » Gloves » CyberGlove Systems
7.6
CyberGlove Systems
This plug-in provides support for the CyberGlove Systems family of devices for capturing tracking data from data gloves. These devices measure finger flexion, abduction between fingers, thumb crossover, palm arch, wrist flexion, and wrist abduction. These devices use standard wireless or USB connectivity.
Initialization
In order to use the plug-in you must first install the CyberGlove Systems driver and configure the device using the Device Configuration Utility (DCU) that comes with the CyberGlove Systems installer. Once the device is connected and working properly within the DCU, you can connect to it within Vizard.
There are two version of the CyberGlove plug-in, depending on the version of the glove you have. If you have a glove from CyberGlove Systems, then you will use the CyberGlove.dle plug-in. If you are using the legacy CyberGlove sold by Immersion, then you will need to use the immersion.dle plug-in. Once created, both plug-ins provide the same interface.
The CyberGlove extension object has  the following methods/constants:
Method
Description
<CyberGlove>.addCyberGlove(port=0, baudRate=115200)
Returns a CyberGlove sensor object on the specified port. If port is 0, the plug-in will automatically detect an attached glove. The baudRate parameter specifies the baud rate the glove is communicating on when connecting to a serial device.
<CyberGlove>.addCyberTouch(port=0, baudRate=115200)
Returns a CyberTouch sensor object. The parameters are the same as the addCyberGlove method above.
<CyberGlove>.TOUCH_THUMB
<CyberGlove>.TOUCH_INDEX
<CyberGlove>.TOUCH_MIDDLE
<CyberGlove>.TOUCH_RING
<CyberGlove>.TOUCH_PINKY
<CyberGlove>.TOUCH_PALM
<CyberGlove>.TOUCH_ALL
These constants represent the vibration sensors on the CyberTouch device. The values are bit flags, so they can be combined using the bitwise OR operator.
The CyberGlove sensor object provides raw data through the sensor.getData() method. The data returned is a list containing the following values:
Note: All the joint values are in degrees
Index
Description
0
Thumb roll
1
Thumb inner joint
2
Thumb outer joint
3
Index finger inner joint
4
Index finger middle joint
5
Index finger outer joint
6
Middle finger inner joint
7
Middle finger middle joint
8
Middle finger outer joint
9
Ring finger inner joint
10
Ring finger middle joint
11
Ring finger outer joint
12
Pinky finger inner joint
13
Pinky finger middle joint
14
Pinky finger outer joint
15
Thumb-Index abduction
16
Index-Middle abduction
17
Middle-Ring abduction
18
Ring-Pinky abduction
19
Palm arch
20
Wrist flexion
21
Wrist abduction
22
Switch state
23
Gesture number
The CyberTouch sensor object is the same as the CyberGlove sensor, but contains the following additional methods for controlling the vibration sensors of the glove:
Method
Description
<cybertouch>.setVibration(sensor, value)
Set the vibration level of a CyberTouch sensor. sensor is a combination of the above vibration sensor constants. Combining multiple constants allows you to set the vibration level of multiple sensors simultaneously. value is a number between 0 and 1, that controls the vibration level. 0 is no vibration and 1 is maximum vibration.
<cybertouch>.getVibration(sensor)
Returns the vibration level of the specified vibration sensor. sensor must be one of the vibration sensor constants.
<cybertouch>.clearVibration()
Clear the vibration level of all vibration sensors.
Example
This example shows how to add a CyberGlove sensor in your script. Add a sensor for each glove you want to use.
CyberGlove = viz.add('CyberGlove.dle')
glove = CyberGlove.addCyberGlove()
data = glove.getData()
The following examples shows how to add a CyberTouch sensor and set the vibration amplitude of the index and pinky finger to 75%:
glove = CyberGlove.addCyberTouch()
glove.setVibration( CyberGlove.TOUCH_INDEX | CyberGlove.TOUCH_PINKY , 0.75 )
See also
In this section:
5DT data glove
5DT plug-in
Other sections:
Tutorial: 5DT data gloves - Tutorial in the Hardware section on how to use a 5DT data glove.
