Reference: Application window
Taking screenshots and recording screen videos
Taking screenshots
To get a screenshot of the graphics window, use viz.window.screenCapture(<image filename>).
#Hit the 's' key for a screen capture.
#Save that files as 'image.bmp'.
vizact.onkeydown( 's', viz.window.screenCapture, 'image.bmp' )
You can also press Ctrl+F9 while your script is running to create a screenshot. The screenshot will be saved in the current script directory with the filename "vizard-<year><month><day>-<time>.bmp". Since the filename is time stamped, you can take multiple screenshots without having them overwrite each other.
Recording videos of the screen
To record 'avi' video files of the screen use viz.window.startRecording and viz.window.stopRecording (or viz.window.toggleRecording). Note: Vizard will adjust the screen to the maximum recording size for the avi.
vizact.onkeydown('b', viz.window.startRecording, 'test.avi' )
vizact.onkeydown('e', viz.window.stopRecording )
You can also press Ctrl+F12 while your script is running to toggle AVI recording. The video will be saved in the current script directory with the filename "vizard-<year><month><day>-<time>.avi".
You can use the following option strings to configure the AVI recorder:
Option name
Description
Default value
viz.AVIRecorder.maxWidth
Maximum video width
640
viz.AVIRecorder.maxHeight
Maximum video height
480
viz.AVIRecorder.fps
Video framerate
30
viz.AVIRecorder.drawCursor
Draw mouse cursor in video (0 or 1)
0
NOTE: Videos are recorded uncompressed, which means the file size will grow very large very quickly. Make sure you have enough hard drive space before recording.
See also
In this section:
Application window basics
Application Command Table
Other sections:
Video Basics
Recording sound with vizmic
