Reference: Stereo & Displays
Lens correction
Vizard can perform lens correction on the output image to account for distorted displays, such as HMDs. The vizlens module has a distortion correction implementation that will perform a standard pincushion distortion on the output image. Simply add the following code to your script to enable the distortion correction:
import vizlens
pincushion = vizlens.PincushionDistortion()
The PincushionDistortion constructor accepts the following optional keyword arguments:
Argument
Description
Default
k1
The amount of distortion to perform. You can specify the default value using the PincushionDistortion.k1 cfg option.
0.1
scaleToFit
Scale the distorted image so that it takes up the entire window.  You can specify the default value using the PincushionDistortion.scaleToFit cfg option.
True
