Vizard 8 » Reference » Tools » Highlighter
8.3.1
Highlighter
The highlighter tool allows for an object to be highlighted. The main purpose of the highlighter is in collaborative tasks. The following command creates a Highlighter object:
Command
Description
highlighter.Highlighter(highlightOnCollision=True,
                             highlightMode=highlighter.MODE_OUTLINE)
highlightOnCollision: Determines whether or not an object is highlighted when it collides with the highlighter.
highlightMode: Can be highlighter.MODE_ARROW, highlighter.MODE_OUTLINE, highlighter.MODE_BOX
The following methods are available on the Highlighter object:
Method
Description
<Highlighter>.getHighlightMode()
Returns the highlighter mode.
<Highlighter>.setHighlightMode(highlightMode)
Sets the highlight mode.
<Highlighter>.setItems()
Sets the objects that can be highlighted.
items: a list of Vizard nodes.
<Highlighter>.highlight()
Sends a ray from the highlighter node (hand, arrow, etc.) to intersect and highlight objects.
<Highlighter>.getSelection()
Returns the current object highlighted by the highlighter. Can be None if there is no object.
<Highlighter>.clear()
Clears the highlight from the highlighted object.
<Highlighter>.remove()
Removes the highlighter.
<Highlighter>.setUpdateFunction(updateFunction)
Sets the update function that gets called every frame. The update function calls methods on the tool based on the state of input devices.
The following event is triggered when the highlighted object changes:
Event
Description
highlighter.HIGHLIGHT_EVENT
This event is generated when the object highlighted by the highlighter is updated. It provides a single event structure e with the following attributes:
e.new: The object currently highlighted by the highlighter. Returns None if there is no object.
e.old: The object that was previously highlighted by the highlighter. Returns None if there was no object.
Example
Scroll wheel moves the arrow forward,back.
Left mouse button draws a ray to highlight.
Mouse movements control viewpoint orientation.
Arrow Keys control viewpoint position.
Space bar changes the highlight mode
import viz
import vizact
import vizshape
import vizinfo
viz.setOption('viz.display.stencil',1)
vizinfo.InfoPanel()
viz.setMultiSample(4)
viz.fov(60)
environment = viz.addChild('sky_day.osgb')
soccerball = viz.addChild('soccerball.osgb',pos=[-1,1.8,2])
basketball = viz.addChild('basketball.osgb',pos=[0,1.8,2])
volleyball = viz.addChild('volleyball.osgb',pos=[1,1.8,2])
#Add a model to represent the tool
arrow = vizshape.addArrow(length=0.2, color = viz.ORANGE)
#Initialize the Highlighter and items that can be highlighted
from tools import highlighter
tool = highlighter.Highlighter()
tool.setItems([soccerball,basketball,volleyball])
# update code for highlighter
def updateHighlighter(tool):
    state = viz.mouse.getState()
    if state & viz. MOUSEBUTTON_LEFT:
        tool.highlight()
        tool.clear()
tool.setUpdateFunction(updateHighlighter)
#Link the highlighter to an arrow in order to
#visualize it's position
from vizconnect.util import virtual_trackers
mouseTracker = virtual_trackers.ScrollWheel(followMouse = True)
mouseTracker.distance = 0.7
arrowLink = viz.link(mouseTracker,arrow)
arrowLink.postMultLinkable(viz.MainView)
viz.link(arrowLink,tool)
#Cycle the highlight mode with the spacebar
modes = viz.cycle([highlighter.MODE_BOX, highlighter.MODE_ARROW, highlighter.MODE_OUTLINE])
def cycleMode():
    tool.setHighlightMode(modes.next())
vizact.onkeydown(' ',cycleMode)
#Register a callback function for the highlight event
def onHighlight(e):
    if e.new == soccerball:
        print('soccerball is highlighted')
viz.callback(highlighter.HIGHLIGHT_EVENT,onHighlight)
import vizcam
vizcam.FlyNavigate()
#Hide the mouse curser
viz.mouse.setVisible(viz.OFF)
