Vizard 8 » Reference » Input Devices » Gloves » 5DT Data Glove
8.3.1
5DT Data Glove plug-in
This plug-in provides support for the 5DT family of devices for capturing tracking data from 5DT data gloves. These devices measure finger flexion, abduction between fingers, and recognize a set of hand gestures. Some models also measure palm and wrist bend, and pitch and roll of the hand.
Initialization
The 5DT plug-in will use the following global variables during initialization:
Variable
Description
PORT_5DT
If connecting over serial, this variable specifies the COM port the glove is connected on. Default 1.
PORT_5DT_USB
If connecting over USB, this variable specifies which USB device number to connect to. The first device is 0, the second is 1, and so on.
Note: When you first connect to the glove, the data is uncalibrated. You need to open and close the hands so that the entire range of motion is detected.
Example
This example shows how to add a 5DT data glove sensor in your script. Add a sensor for each glove you want to use, specifying the glove's port.
PORT_5DT_USB = 0 #Connect to first USB device
glove = viz.add('5dt.dls')
data = glove.getData() #Get glove data
The object "data" will be an array containing the raw data from your device. By default, the data has been scaled according to the calibration. Use the command described in "Advance Options" below to retrieve raw data. If you are using Data Glove 5 or Data Glove 7, the data are located in the following positions within the array:
Position
Description
0
Thumb near
1
Index near
2
Middle finger near
3
Ring near
4
Little finger near
5
Pitch
6
Roll
7
Gesture number
If you are using Data Glove 14 or Data Glove 16, the data are located in the following positions within the array:
Position
Description
0
Thumb near
1
Thumb far
2
Thumb index abduction
3
Index near
4
Index far
5
Index middle abduction
6
Middle near
7
Middle far
8
Middle ring abduction
9
Ring near
10
Ring far
11
Ring little abduction
12
Little near
13
Little far
14
Thumb palm
15
Wrist bend
16
Pitch
17
Roll
18
Gesture number
Advanced options
The "command" methods for this plug-in allow you to switch back and forth between raw data and data that has been scaled according to the calibration data.
Command number
Description
0
use scaled data (default)
1
use raw data
Example:
glove.command(0)  # Set the plug-in to retrieve scaled data.
