Vizard 8 » Tutorials & Examples » Python Programming » An example
8.3.1
An example
So what does all this have to do with virtual worlds? Let's run a script in Vizard and see. Open a new Vizard file and save it to a convenient location.
In this script, we'll treat some 3D objects as variables and manipulate them with some of our logic. The following lines will create a row of pigeons with a for statement. Read through them and then run the script:
import viz
import vizact
viz.setMultiSample(4)
viz.fov(60)
#Create an empty array to put some pigeons in.
pigeons = []
#Go through a loop six times.
for eachnumber in range(6):
    #Each time you go through the loop, create a new pigeon
    newPigeon = viz.addAvatar('pigeon.cfg')
    #Place the new pigeon on the x-axis.
    #Each time the script goes through the loop, "eachnumber"
    #will be one larger so the pigeons will fall in a line
    #along the x-axis
    newPigeon.setPosition([eachnumber, 0,5])
    #Add the new pigeon to the "pigeons" array.
    pigeons.append(newPigeon)
    #If the new pigeon is one of the first two created,
    #make it spin around the x #axis.
    if eachnumber < 2:
        newPigeon.add(vizact.spin(1,0,0,90))
    #If the new pigeon is one of the second two, make it spin around the y axis.
    elif eachnumber >= 2 and eachnumber < 4:
        newPigeon.add(vizact.spin(0,1,0,90))
    #If the new pigeon is one of the remaining two,
    #make it spin around the z axis.
        newPigeon.add(vizact.spin(0,0,1,90))
#move the view to see all pigeons
viz.MainView.move([2.5,-1.5,1])
Speaking Vizard's language
A quick note: Tips on scripts
Looping logic
If-then logic
Functions
An example
