Vizard 8 » Reference » 3D models » Text nodes » Text node command table
8.3.1
Viz command for adding text
<viz>.addText
Node3d commands for text parameters
(3D text nodes also inherit the more general node3d commands)
<node3d>.getMessage
<node3d>.getResolution
<node3d:text3d>.alignment
<node3d:text3d>.font
<node3d:text3d>.fontSize
<node3d:text3d>.message
<node3d:text3d>.resolution
Alignment Modes
Mode
Description
viz.ALIGN_LEFT_TOP
Text is aligned with upper left corner
viz.ALIGN_LEFT_CENTER
Text is aligned with center left side
viz.ALIGN_LEFT_BOTTOM
Text is aligned with bottom left corner
viz.ALIGN_CENTER_TOP
Text is aligned with center top side
viz.ALIGN_CENTER_CENTER
viz.ALIGN_CENTER_BOTTOM
Text is aligned with center bottom side
viz.ALIGN_RIGHT_TOP
Text is aligned with upper right corner
viz.ALIGN_RIGHT_CENTER
Text is aligned with center right side
viz.ALIGN_RIGHT_BOTTOM
Text is aligned with bottom right corner
See also
In this section:
3D text basics
Other sections:
3D model command tables
GUI command table
Example scripts:
3D text
