Vizard 8 » Reference » Global settings » Global settings
8.3.1
Global settings
You can setup a default Vizard environment by configuring the vizcore.cfg file.  This allows you to set the default resolution, window dimensions, GUI color theme, and more.  To set these default values, create a vizcore.cfg file in Vizards /bin directory.  Then add the configuration options you are interested in by following the example vizcore.cfg file below. If there is a vizcore.cfg file in the same directory as the script, Vizard will load this as well. If the same option is specified in both the global and local vizcore.cfg file, the local copy will take precedence.
You can also dynamically set and read options in your script using the viz.setOption(name,value) and viz.getOption(name[,default]) commands.
The viz.setOption() command will set the value of the specified option name. If the option does not exist, it will be created, otherwise it will override the existing value. If the value is None then the option will be removed.
#Set the AVI recorder to record at 29.97 frames per seconds
viz.setOption('viz.AVIRecorder.fps','29.97')
The viz.getOption() command will return the string value of the specified option name. If the option does not exist, the specified default value will be returned.
#Print the Vizard version number
print( viz.getOption('viz.version'))
Example vizcore.cfg
Here is a sample vizcore.cfg file that will perform the following for all scripts:
viz.antialias = 4
# Lines beginning with the '#' symbol will be treated as comments
viz.fullscreen = 1
viz.clearcolor = 0.5 0.5 0.5
Window initialization options
These options must be set before viz.go() is called.
Name
Description
Default value
viz.antialias
Specifies the full screen anti-alias sample number
0
viz.window.width
Initial non-fullscreen width of the window
800
viz.window.height
Initial non-fullscreen height of the window
600
viz.window.x
Initial x position of non-fullscreen window. Relative to upper left corner.
0
viz.window.y
Initial y position of non-fullscreen window. Relative to upper left corner.
0
viz.window.icon
Name of .ico file to use as icon for graphics window and published EXE.
viz.window.visible
Controls the visibility of the graphics window
1
viz.display.width
Resolution width of monitor to run Vizard simulation in
0
viz.display.height
Resolution height of monitor to run Vizard simulation in
0
viz.display.color
Color resolution of monitor to run Vizard simulation in
0
viz.display.frequency
Monitor refresh rate to run Vizard in
0
viz.display.alpha
Number of alpha bits to request when creating OpenGL context
0
viz.display.stencil
Number of stencil bits to request when creating OpenGL context
0
viz.display.swap_copy
When swapping buffers, copy contents of back buffer into front buffer, instead of exchanging contents (default).
0
viz.display.gpu_affinity
Enable/Disable nVidia GPU affinity option. If enabled and supported by your graphics driver, all rendering will be performed on the GPU associated with the monitor the graphics window is initially created on.
0
viz.display.swap_group Enable/Disable nVidia swap group option. If enabled, buffer swaps will be synchronized with all other Vizard windows running on the same machine. 0
viz.display.swap_barrier Enable/Disable nVidia swap barrier option. If enabled and swap group is also enabled, buffer swaps will be synchronized with all other Vizard windows assigned to the barrier group. 0
viz.hmd
Initialize in HMD mode
0
viz.fullscreen
Initialize in fullscreen mode
0
viz.fullscreen.monitor
The monitor to use for fullscreen operations. If 0, the entire combined monitor region will be used for fullscreen.
0
viz.fullscreen.width
The width to use for fullscreen mode. If 0, the monitor width will be used.
0
viz.fullscreen.height
The height to use for fullscreen mode. If 0, the monitor height will be used.
0
viz.fullscreen.x
The x position to use for fullscreen mode. Relative to upper left corner.
0
viz.fullscreen.y
The y position to use for fullscreen mode. Relative to upper left corner.
0
viz.prompt
Initialize with prompt window
0
viz.stereo
Default stereo mode if none is specified with viz.go()
0
viz.quadbuffer
Initialize in quad buffer stereo mode
0
viz.stencil
Initialize with stencil buffer
0
Global initialization options
These options must be set in vizcore.cfg file, before the script is executed.
viz.theme.border
Theme border color
0.25 0.35 0.45 1.0
viz.theme.text
Theme text color
1.0 1.0 1.0 1.0
viz.theme.back
Theme background color
0.58 0.68 0.78 1.0
viz.theme.lightBack
Theme light background color
0.68 0.75 0.83 1.0
viz.theme.darkBack
Theme dark background color
0.25 0.44 0.64 1.0
viz.theme.highBack
Theme highlight background color
0.25 0.44 0.64 1.0
viz.theme.highText
Theme highlight text color
1.0 0.78 0.34 1.0
viz.theme.check.down
Checkbox check texture
viz.theme.check.up
Checkbox uncheck texture
viz.theme.button.down
Button down texture
viz.theme.button.up
Button up texture
viz.theme.radio.down
Radio selected texture
viz.theme.radio.up
Radio unselected texture
viz.theme.slider.bar
Slider bar texture
viz.theme.slider.tick
Slider tick texture
viz.logLevel
Output log level (LOG_ALWAYS, LOG_ERROR, LOG_WARN, LOG_NOTICE, LOG_INFO, LOG_DEBUG)
LOG_NOTICE
viz.resource.path
Semi-colon delimited string of directories to add to resource path.
viz.resource.loaderOption
File loader option string
viz.physics.engine
The default physics engine to load on startup.
physics_opal.dll
viz.sound3d.engine
The default sound 3d engine to load on startup.
sound3d_dx.dll
viz.vsync
Vertical sync mode
1
viz.ipd
Stereo IPD value
0.06
viz.fov
Field of View and aspect ratio. If aspect ratio is negative then it will be automatically computed based on window size.
40 -1
viz.clip
Near/Far clip plane. If either value is negative, the clip planes will be automatically computed.
-1 -1
viz.overlap
Stereo overlap
1.0
viz.screenDistance
Screen distance value for stereo modes.
1.0
viz.clearcolor
Window clear color
0 0 0
viz.stereoHUD
Controls whether HUD objects are rendered in stereo. 0 or 1
1
viz.clearDepth
Clear depth buffer when rendering screen objects.
1
viz.specularTexture
Enables/Disables specular highlights on all textured objects.
0
viz.lightModel.localViewer
Use local viewpoint for calculating specular highlights. Enabling this will fix problems with specular highlights not being consistent on CAVE edges.
0
viz.lightModel.twoSided
Enable/Disable two sided lighting calculations.
0
viz.lightModel.ambient
Set the global ambient color
0.2 0.2 0.2
viz.text.encoding
The encoding to use for text display. If AUTO, Vizard will check the script for a UTF8 BOM.
( AUTO, ASCII, UTF8)
AUTO
viz.text.font
The default font to use when creating text objects.
Arial
viz.text.bidirectional
Controls whether text will support displaying bidirectional UTF-8 characters.
0
viz.text.line_spacing
The default line spacing to use when creating text objects. The spacing is specified as a percentage of the character height.
0.0
viz.text.thickness
The default thickness to use when creating 3D text objects. The thickness is specified as a percentage of the character height.
0.1
viz.network.buffer_size
Size of buffer that will receive all network data.
65536
viz.network.port
Port used for sending/receiving network data.
4950
viz.network.port_in
Space delimited list of additional ports to receive network data on.
viz.splashscreen
Image file to use as a loading splash screen
viz.mouse.visible
Controls if the mouse cursor is visible.
1
viz.mouse.trap
Controls if the mouse cursor is trapped inside the Vizard graphics window.
0
viz.mouse.sensitivity
Mouse navigation sensitivity.
1 1
viz.cluster.master.clients
Space delimited list of clients to connect to in cluster. Cluster master application will take precedence over this option.
viz.cluster.master.port
Port to use for cluster communication.
8501
viz.cluster.master.sync
Enable/Disable synchronization of frames between cluster nodes.
1
viz.cluster.master.sync_gpu
Controls whether GPU processing is synchronized between cluster nodes. Only used if frame synchronization is also enabled.
0
viz.cluster.master.transmit_mouse
Enable/Disable transmitting mouse navigation to clients.
1
viz.cluster.master.buffer_flush_size
Number of bytes in cluster message buffer before sending to clients.
4096
viz.cluster.master.broadcast_address
The address to use for broadcasting sync signal to clients.
255.255.255.255
viz.cluster.master.abortOnLostConnection
Controls whether the cluster master will abort the simulation if the connection to a client is lost.
1
viz.cluster.connect_timeout
Timeout for connecting to master/clients (milliseconds)
15000
viz.cluster.sync_timeout
Timeout for syncing frame with other machines (milliseconds)
10000
viz.cluster.frame_timeout
Timeout for sending/receiving messages for a frame (milliseconds)
20000
python.optimize
Set the optimize flag to initialize the Python interpreter with. Can be one of the following values:
0 - No optimization (default value)
1 - Equivalent to -O option, ignores assert statements
2 - Equivalent to -OO option, doc strings will not be included in compiled pyo files.
0
 Miscellaneous options
These options must be set before the associated commands are executed.
viz.default_key.quit
Enable/Disable default key for quitting Vizard script
1
viz.default_key.display_html
Enable/Disable default key for toggling display of html help
1
viz.default_key.fullscreen
Enable/Disable default key for toggling fullscreen mode
1
viz.default_key.poly_mode
Enable/Disable default key for toggling through polygon mode
1
viz.default_key.framerate
Enable/Disable default key for toggling framerate display
1
viz.default_key.camera_reset
Enable/Disable default key for resetting camera handler
1
viz.default_key.capture_image
Enable/Disable default key for capturing screen to an image
1
viz.default_key.capture_video
Enable/Disable default key for recording screen to a video
1
viz.default_key.dock_window
Enable/Disable default key for toggling docking of script window within IDE
1
viz.default_key.interactive
Enable/Disable default key for activating interactive window of IDE
1
viz.AVIRecorder.maxWidth
Maximum width for recording AVI
640
viz.AVIRecorder.maxHeight
Maximum height for recording AVI
480
viz.AVIRecorder.fps
Frame rate for recording AVI
30
viz.AVIRecorder.drawCursor
Capture mouse cursor in AVI
0
viz.check_gl_errors
Controls whether Vizard performs fine grained OpenGL error checking.
0
viz.glFinish
Controls whether Vizard synchronizes with the GPU after swapping the frame buffer by calling glFinish().
0
viz.dwm_composition
Controls whether Desktop Window Manager (DWM) composition is allowed while the script is running.
1
viz.preload
Tells Vizard if it should preload all objects to the graphics card before rendering the first frame.
1
viz.hint
A combination of hint flags to apply on all the scenes before the first frame is rendered.
0
viz.node.op_mode
Specifies the default op mode to use when a node is created. Can be a combination of the following values:
4 - OP_TRAVERSE
8 - OP_OVERRIDE
16 - OP_ROOT
4
viz.model.optimize
Automatically optimize models after they are loaded.
0
viz.model.hint
A combination of hint flags to apply to all loaded models.
0
viz.model.cache
The default cache mode to use. Can be one of the following values:
0 - viz.CACHE_NONE
1 - viz.CACHE_COPY
2 - viz.CACHE_CLONE
0
viz.model.apply_collada_scale
Automatically apply embedded meter scale factor to loaded Collada models.
1
viz.model.apply_collada_node_name Apply the Collada node name to the Vizard node during load, instead of the node ID. 0
viz.texture.share
Tells Vizard if it should share the textures of a model after it is loaded. This helps save texture memory when loading models that reference the same image file.
1
viz.texture.hint
A combination of hint flags to apply to textures created with viz.addTexture command. Will not be applied to render/blank textures.
0
vizhtml.port The port vizhtml's HTTP server will communicate over. 8080
viznet.server.port
The port viznet servers will communicate over.
viz.NETWORK_PORT
viznet.server.port_in
The port for viznet servers to receive messages on. If not specified, it will inherit the value from the viznet.server.port option.
viznet.server.port
viznet.server.port_out
The port the viznet servers will send messages on. If not specified, it will inherit the value from the viznet.server.port option.
viznet.server.port
viznet.client.port
The port viznet clients will communicate over.
viz.NETWORK_PORT
viznet.client.port_in
The port for viznet clients to receive messages on. If not specified, it will inherit the value from the viznet.client.port option.
viznet.client.port
viznet.client.port_out
The port the viznet clients will send messages on. If not specified, it will inherit the value from the viznet.client.port option.
viznet.client.port
hd.version
Version of OpenHaptics plugin to use. Can be either 1 or 2. Must be set before hd module is imported.
2
viz.shader.normal_map_unit
The texture unit to use when generating tangent/binormal data for geometry.
0
viz.shader.tangent.name
The attribute name to use for tangent data.
Tangent
viz.shader.tangent.index
The attribute index to use for tangent data.
6
viz.shader.binormal.name
The attribute name to use for binormal data.
Binormal
viz.shader.binormal.index
The attribute index to use for binormal data.
7
viz.link.resetOriPriority
The priority to use for link reset ori operators.
-10
LiveCharacter.connectionWarnTimeout
Print warning if LiveCharacter has not received response from server after this many seconds.
2
LiveCharacter.connectionRetryTimeout
Retry connecting to LiveCharacter server if have not received update after this many seconds.
2
viz.publish.allow_capture_video Allows capturing video recordings within published EXEs. Disabled by default since end users could inadvertently trigger recording that could quickly fill up hard drive space. 0
viz.publish.crc
Controls whether published EXEs will perform CRC on the exe when running. Set to 0 if you need to disable the CRC check.
1
viz.publish.load_message
Message to display in popup box while publish EXE is loading. If set to an empty string, the popup box will not appear.
Vizard launching, please wait...
viz.publish.load_title
Title of popup box while publish EXE is loading. The title appears in the taskbar.  If set to an empty string, the popup box won't appear in the taskbar.
Vizard launching
viz.publish.persistent
Controls whether the contents of the published EXE will persist on the users drive after being unpacked. If enabled, you must also specify a unique name for the viz.publish.product option. The files will persist in a directory based on the specified company/product names:
 %TEMP%/<company>/<product>
When enabled, this option allows for much faster startup times of the published EXE, since it will only need to be unpacked once on the end users system, and subsequent executions will run form the existing directory.
0
viz.publish.persist_folder
The folder to unpack persistent EXEs to. Must begin with one of the following tags:
<temp> - Users temp folder
<appdata> - Users application data folder
<temp>/<company>/<product>
viz.publish.product
The product name to use for published EXEs
viz.publish.company
The company name to use for published EXEs
WorldViz
viz.prevent_screensaver
Controls whether Vizard should prevent the screen saver from starting while the script is running.
0
viz.max_frame_rate
The maximum framerate to allow Vizard to run at. If 0, then Vizard will run as fast as possible.
0
viz.html.allowEscape
Controls whether the Escape key will close the HTML window when it as focus.
1
viz.director.exit_timeout Number of seconds to wait for director functions to exit during shutdown. 2
sound3d.useViewRotation
Controls whether the viewpoint rotation is used for spatializing the sound.
1
sound3d.dx.algorithm
The algorithm used by the DirectX 3D sound plugin. Can be one of the following string values:
NO_VIRTUALIZATION
HRTF_FULL
HRTF_LIGHT
If no value is specified, a default algorithm will be selected based on the user preference in the Control Panel.
Information options
These options are read-only.
platform.bit Current Vizard platform bit number 32 or 64
platform.name Current Vizard platform name win32 or x64
viz.version
Current version of vizard
NA
viz.monitor.count
Number of monitors
NA
viz.monitor.width
Current width of monitor resolution.
NA
viz.monitor.height
Current height of monitor resolution.
NA
viz.monitor.refresh_rate
Current refresh rate of monitor
NA
viz.cluster
1 if running in cluster mode, otherwise 0
NA
viz.cluster.clients
Number of clients, when running in cluster mode.
NA
viz.publish
1 when running in published mode, otherwise 0.
NA
viz.publish.path
The path of the published exe, when running in published mode.
NA
gl.extensions
List of OpenGL extensions supported by graphics card. Extension names are separated with spaces.
NA
gl.version
OpenGL version supported by driver
NA
gl.vendor
OpenGL driver vendor. Typically maker of graphics card.
NA
gl.renderer
OpenGL renderer. Typically name of graphics card.
NA
gl.shading_language_version
OpenGL shading language version
NA
gl.max_texture_size
Maximum 2D texture dimension supported by driver
NA
gl.max_3d_texture_size
Maximum 3D texture dimension supported by driver
NA
gl.max_cube_map_texture_size
Maximum Cubemap texture dimension supported by driver
NA
gl.max_texture_units
Maximum fixed function texture units supported by driver
NA
gl.max_texture_image_units
Maximum fragment shader texture units supported by driver
NA
gl.max_vertex_texture_image_units
Maximum vertex shader textures units supported by driver
NA
gl.max_combined_texture_image_units
Maximum vertex and fragment shader texture units supported by driver
NA
gl.colorBits
Color buffer bit depth of created window
NA
gl.redBits
Red channel bit depth of created window
NA
gl.greenBits
Green channel bit depth of created window
NA
gl.blueBits
Blue channel bit depth of created window
NA
gl.alphaBits
Alpha channel bit depth of created window
NA
gl.depthBits
Depth buffer bit depth of created window
NA
gl.stencilBits
Stencil buffer bit depth of created window
NA
gl.stereo
1 if quad buffer stereo is supported by created window, otherwise 0
NA
gl.pixelFormatIndex
The selected pixel format index of the created window
NA
gl.multiSamples
Multi sampling level of created window
NA
