Vizard 8 » Tutorials & Examples » 3D models » Creating 3D models on-the-fly » Tutorial: Finding shapes
8.3.1
In this section of the tutorial we'll determine when a shape has been found by the user and mark it's location in the bird's eye map.
First, let's create an OTF layer of points to use for marking the map:
#Add points for found shapes
viz.startLayer(viz.POINTS)
viz.pointSize(5)
viz.vertexColor(viz.RED)
points = viz.endLayer()
points.disable(viz.CULLING)
points.renderOnlyToWindows([BirdEyeWindow])
Proximity to a shape will be the factor that determines when it has been found. For this we'll import the vizproximity library:
import vizproximity
Next, a fading action is defined that will be applied to shapes that are found by the user:
#Create action for when shape is found
fadeColor = vizact.fadeTo(viz.BLUE,time=2)
fadeAlpha = vizact.fadeTo(0.4,time=3)
fade = vizact.parallel(fadeColor,fadeAlpha)
Finally, code is added that sets up and handles proximity events. Proximity sensors are applied to each shape and the viewpoint is made a proximity target. When the target enters the range of one of the sensors the following occurs:
def FoundShape(e):
    """Called when the viewpoint enters the proximity area of a shape"""
    # Remove shape sensor from proximity manager
    e.manager.removeSensor(e.sensor)
    # Add fade action to shape
    shape = e.sensor.getSourceObject()
    shape.runAction(fade)
    # Add found position to points
    points.addVertex(shape.getPosition())
    # Show message when all shapes have been found
    if not e.manager.getSensors():
        vizinfo.InfoPanel('Good Job! Game over.',align=viz.ALIGN_CENTER,icon=False)
# Create proximity manager
manager = vizproximity.Manager()
#Use main viewpoint as proximity target
manager.addTarget(vizproximity.Target(viz.MainView))
# Add a spherical proximity sensor for each shape
sphere = vizproximity.Sphere(2.0)
for s in shapes:
    sensor = vizproximity.Sensor(shape=sphere, source=s)
    manager.addSensor(sensor)
    manager.onEnter(sensor,FoundShape)
Run the code now and see what happens when you get near a shape.
Creating an on-the-fly object
Changing vertices on-the-fly
Adding shapes
Finding Shapes
