Vizard 8 » The Vizard IDE » Keyboard shortcuts
8.3.1
Keyboard Shortcuts
The Vizard editor provides the following keyboard combinations for quicker access to common functions:
General
Keyboard combination
Description
F1
Open Vizard documentation
Ctrl + N
New file
Ctrl + O
Open file
Ctrl + Shift + O
Quick Open file
Ctrl + S
Save file
Ctrl + Shift + S
Save all files
Ctrl + W
Close file
Double-Click tab strip
New file
Middle-Click document tab
Close file
Script Execution and Debugging
Description
F5
Run script
Shift + F5
Stop running script
F6
Run script in docked window
Ctrl + F6
Toggle docked state of running script
Ctrl + F5
Run script with debugger
Ctrl + Shift + F5
Stop debugger
Ctrl + F9
Toggle breakpoint
F9
Go to next breakpoint
Shift + F9
Go to previous breakpoint
Ctrl + Shift + F9
Clear all breakpoints
Ctrl + F10
Step Into
Ctrl + F11
Step Over
Ctrl + F12
Step Out
Code Searching and Navigation
Description
Ctrl + F
Open Find dialog
Ctrl + H
Open Find and Replace dialog
Ctrl + Shift + F
Open Find in Files dialog
F3
Go to next find result
Alt + F3 Go to next find result using current selection as search string
Shift + F3
Go to previous find result
Ctrl + F3
Go to next Find in Files result
Ctrl + Shift + F3
Go to previous Find in Files result
Alt + D
Activate Quick Search toolbar
Ctrl + F4
Toggle bookmark
F4
Go to next bookmark
Shift + F4
Go to previous bookmark
Ctrl + Shift + F4
Clear all bookmarks
Ctrl + G
Open Go To Line dialog
Ctrl + J
Locate current scope in Code Browser
Ctrl + B
Select current scope block
F8
Go to next scope definition
Shift + F8
Go to previous scope definition
Middle-Click name
Go To Definition on clicked name
Alt + Left
Navigate Backward
Alt + Right
Navigate Forward
F11
Open script directory
F12
Open Vizard directory
Alt + I
Activate Interactive window
Ctrl + Tab
Toggle through open files
Alt + F7
Toggle through open panes
Ctrl + (1 - 8)
Select tab (1 to 8)
Ctrl + 9
Select last tab
Ctrl + Page Up Select previous tab
Ctrl + Page Down Select next tab
Text Editing
Description
Down
Move down a line
Shift + Down
Move down a line and extend the selection
Ctrl + Down
Scroll down a line
Alt + Shift + Down
Move down a line and extend the rectangular selection
Alt + Down
Move the selected lines down one line
Up
Move up a line
Shift + Up
Move up a line and extend the selection
Ctrl + Up
Scroll up a line
Alt + Shift + Up
Move up a line and extend the rectangular selection
Alt + Up
Move the selected lines up one line
Ctrl + [
Move up a paragraph
Ctrl + Shift + [
Move up a paragraph and extend the selection
Ctrl + ]
Move down a paragraph
Ctrl + Shift + ]
Move down a paragraph and extend the selection
Left
Move left a character
Shift + Left
Move left a character and extend the selection
Ctrl + Left
Move left a word
Ctrl + Shift + Left
Move left a word and extend the selection
Alt + Shift + Left
Move left a character and extend the rectangular selection
Right
Move right a character
Shift + Right
Move right a character and extend the selection
Ctrl + Right
Move right a word
Ctrl + Shift + Right
Move right a word and extend the selection
Alt + Shift + Right
Move right a character and extend the rectangular selection
Ctrl + /
Move left a word part
Ctrl + Shift + /
Move left a word part and extend the selection
Ctrl + \
Move right a word part
Ctrl + Shift + \
Move right a word part and extend the selection
Home
Move to the first non-blank character in the line
Shift + Home
Move to the first non-blank character in the line and extend the selection
Ctrl + Home
Move to the beginning of the document
Ctrl + Shift + Home
Move to the beginning of the document and extend the selection
Alt + Home
Move to the beginning of the line
Alt + Shift + Home
Move to the first non-blank character in the line and extend the rectangular selection
End
Move to the end of the line
Shift + End
Move to the end of the line and extend the selection
Ctrl + End
Move to the end of the document
Ctrl + Shift + End
Move to the end of the document and extend the selection
Alt + Shift + End
Move to the end of the line and extend the rectangular selection
Page Up
Move up a page
Shift + Page Up
Move up a page and extend the selection
Alt + Shift + Page Up
Move up a page and extend the rectangular selection
Page Down
Move down a page
Shift + Page Down
Move down a page and extend the selection
Alt + Shift + Page Down
Move down a page and extend the rectangular selection
Delete
Delete the selection or the character to the right
Shift + Delete
Cut the selection
Ctrl + Delete
Delete the word to the right
Shift + Ctrl + Delete
Delete the line to the right
Insert
Toggle between insert mode and overtype mode
Shift + Insert
Paste the selection
Ctrl + Insert
Copy the selection
Backspace
Delete the selection or the character to the left
Shift + Backspace
Ctrl + Backspace
Delete the word to the left
Alt + Backspace
Undo
Ctrl + Shift + Backspace
Delete the line to the left
Ctrl + Z
Undo
Ctrl + Y
Redo
Ctrl + X
Cut the selection
Ctrl + C
Copy the selection
Ctrl + V
Paste the selection
Ctrl + A
Selects all
Tab
Indent
Shift + Tab
Dedent
Enter
Newline
Shift + Enter
Newline
Ctrl + Enter
Insert newline at the end of the current line
Ctrl + add (numpad)
Zoom in
Ctrl + subtract (numpad)
Zoom out
Ctrl + divide (numpad)
Set zoom to default
Ctrl + L
Line cut
Ctrl + Shift + L
Line delete
Ctrl + Shift + T
Line copy
Ctrl + T
Line transpose
Ctrl + D
Duplicate the current line or selection
Ctrl + U
Change all selected text to lowercase
Ctrl + Shift + U
Change all selected text to uppercase
Alt + 3
Comment region
Alt + Shift + 3
Uncomment region
Alt + T
Tabify region
Ctrl + Shift + W
Toggle display of whitespace
Ctrl + Shift + I
Toggle display of indentation guides
Ctrl + Spacebar Display completion options for current cursor location
Ctrl + ` (grave accent)
Scroll cursor to center of view
Alt + 1 Display dialog for selecting RGB color to insert at cursor location
The following table lists key and mouse combinations:
Keyboard/mouse combination
Description
Alt + mouse wheel
Alt + scroll bar
Synchronize scrolling with other active views
Ctrl + mouse wheel
Zoom in/out
Ctrl + mouse drag
Select multiple text ranges
Alt + mouse drag
Select a rectangular area
Ctrl + Shift + click code fold
Toggle all code folds
Ctrl + click code fold
Toggle folding for line and all children
Ensure line and all children are visible
Graphics Window
The following shortcuts are available when the graphics window of a running script is active:
Description
Escape
Quit Vizard script
F1
Toggle HTML display
F2
Toggle fullscreen mode
F3
Toggle polygon, wire, and point rendering mode
F4
Toggle framerate display
F8
Reset active camera handler
Ctrl + F9
Capture screenshot
Ctrl + F12
Toggle AVI recording
Ctrl + F6 Toggle docking of window within Vizard IDE
Alt + I
Float window and activate Vizard IDE interactive input
