Vizard 8 » Reference » Input Devices » Gaming devices » Laseraid SpaceGrips
8.3.1
Laseraid SpaceGrips
This plug-in provides support for the Laseraid SpaceGrips input device. The SpaceGrips provide button data.
Initialization
The SpaceGrips plug-in is implemented as a Vizard extension sensor. You can specify the COM port of the device when adding the sensor. The SpaceGrips extension contains the following methods/constants:
Function
Description
<spacegrips>.addSensor(port=1,baudRate=38400)
Connect to SpaceGrips device on specified port and baud rate. Returns an extension sensor object.
<spacegrips>.LBUTTON1
<spacegrips>.LBUTTON2
<spacegrips>.LBUTTON3
<spacegrips>.LBUTTON4
<spacegrips>.RBUTTON1
<spacegrips>.RBUTTON2
<spacegrips>.RBUTTON3
<spacegrips>.RBUTTON4
Button numbers for left/right SpaceGrips device.
The SpaceGrips extension sensor will generate the standard sensor button events
Example
Here is a sample script that connects to a SpaceGrips device. It creates a quad for each button that will turn red while the button is down and white while it is up:
#Add the spacegrips extension
spacegrips = viz.add('spacegrips.dle')
#Connect to device on default port
sensor = spacegrips.addSensor()
#Create list of quads for displaying state of each button
buttons = [ viz.addTexQuad(parent=viz.SCREEN,size=100,pos=(x*0.1+0.1,0.1,0)) for x in range(sensor.getButtonCount()) ]
#Register callback for button presses
def gripDown(e):
    if e.object is sensor:
        buttons[e.button].color(viz.RED)
viz.callback(viz.SENSOR_DOWN_EVENT,gripDown)
#Register callback for button releases
def gripUp(e):
        buttons[e.button].color(viz.WHITE)
viz.callback(viz.SENSOR_UP_EVENT,gripUp)
