This implementation provides support for Matrox video capture cards. You must have the Matrox Imaging Library (MIL) installed in order to use this implementation.
Note: VideoVision must be installed in order to use the Matrox video camera implementation.
This example connects to a camera on a Matrox Morphis Quad card:
The Matrox camera implementation provides the following video camera extension commands:
Method |
Description |
video.addMeteor(gray=False) |
Connect to a camera on a Matrox Meteor card. If gray is True, the camera will capture in gray scale color, otherwise it will use the default color mode. |
video.addMorphisDual(gray=False) |
Connect to a camera on a Matrox Morphis Dual card. If gray is True, the camera will capture in gray scale color, otherwise it will use the default color mode. |
video.addMorphisQuad(gray=False) |
Connect to a camera on a Matrox Morphis Quad card. If gray is True, the camera will capture in gray scale color, otherwise it will use the default color mode. |
