Vizard 8 » Tutorials & Examples » Example scripts » Proximity Sensors » Proximity sensors
8.3.1
Proximity sensors
\examples\proximity\proximitySensors.py
This program demonstrates 3D proximity sensors.
Use the mouse and arrow keys to fly around the proximity sensors
Press spacebar to toggle debug shapes
import vizcam
import vizproximity
viz.fov(60)
viz.add('dojo.osgb')
import vizinfo
vizinfo.InfoPanel()
# Setup fly navigator
cam = vizcam.FlyNavigate()
viz.cam.setHandler(cam)
# Create proximity manager
manager.setDebug(True)
# Add main viewpoint as proximity target
target = vizproximity.Target(viz.MainView)
manager.addTarget(target)
# Create sphere sensor attached to static matrix
sensor = vizproximity.Sensor(vizproximity.Sphere(1.0),source=viz.Matrix.translate(2,1.5,1))
manager.addSensor(sensor)
# Create composite sensor attached to a node
group = viz.addGroup()
group.setPosition(0,1.5,5)
action = vizact.sequence( vizact.moveTo([-4,1.5,5],speed=1), vizact.moveTo([4,1.5,5],speed=1), viz.FOREVER)
group.addAction( action)
shapes = []
shapes.append(vizproximity.Box([1,1,1]))
shapes.append(vizproximity.Sphere(0.5,center=[0,1,0]))
sensor = vizproximity.Sensor(vizproximity.CompositeShape(shapes),group)
# Create box sensor attached to tracker
tracker = viz.add('testtrack_all.dls')
trackerLink = viz.link(tracker,viz.NullLinkable,offset=(0,1,0))
sensor = vizproximity.Sensor(vizproximity.Box([0.5,0.5,0.5]),trackerLink)
# Create sensor using bounding box of node
node = viz.addChild('plant.osgb',pos=(8,0,6))
node.addAction(vizact.spin(0,1,0,45,viz.FOREVER))
sensor = vizproximity.addBoundingBoxSensor(node)
# Create sensor using bounding sphere of node
node = viz.addChild('beachball.osgb',pos=(-8,1.5,6))
action = vizact.sequence( vizact.sizeTo([2,2,2],speed=1), vizact.sizeTo([1,1,1],speed=1), viz.FOREVER)
node.addAction(action)
sensor = vizproximity.addBoundingSphereSensor(node)
# Create sensor using bounding box of sub-node
node = viz.addChild('logo.ive',pos=(-4,0,7))
action = vizact.sequence( vizact.moveTo([-4,1,7],speed=1), vizact.moveTo([-4,0,7],speed=1), viz.FOREVER)
sensor = vizproximity.addBoundingBoxSensor(node,name='Sphere01-FACES')
# Create sensor using avatar bone
avatar = viz.addAvatar('vcc_male2.cfg',pos=[4, 0, 7],euler=[180,0,0])
avatar.state(5)
head = avatar.getBone('Bip01 Head')
sensor = vizproximity.Sensor(vizproximity.Sphere(0.3,center=[0,0.1,0]),head)
# Register callbacks for proximity sensors
def EnterProximity(e):
    print('Entered',e.sensor)
def ExitProximity(e):
    print('Exited',e.sensor)
manager.onEnter(None, EnterProximity)
manager.onExit(None, ExitProximity)
# Press spacebar to toggle debug shapes
vizact.onkeydown(' ',manager.setDebug,viz.TOGGLE)
