Vizard 8 » Tutorials & Examples » Flow control » Actions » Tutorial: Action objects
8.3.1
This tutorial will teach you how to perform a sequence of built-in animations on an object.  In this example we will add a model of a wheelbarrow and make it move along a square path.
Note: this content is discussed in more detail in the Action basics reference section.
Starting an action object
If you have trouble getting the code in this tutorial to work, you can find the complete example actions.py in the \tutorials\flowControl directory.
Enter the following lines into your script:
viz.setMultiSample(4)
viz.fov(60)
viz.addChild('ground.osgb')
wheel = viz.addChild('wheelbarrow.ive')
viz.MainView.move([0,0,-7])
viz.clearcolor(viz.SKYBLUE)
This initializes Vizard, adds some models, moves the viewpoint back 7 meters, and sets the background color to sky blue. The first thing we need to do is create the actions for the wheel barrow. We will be using the vizact library. This library contains many built-in animations that you can apply to most 3d objects.
Action objects
Building an action
Applying an action
