Vizard 8 » Introduction » Activating your license » Unregister license
8.1
Unregister license
If you need to move your license to another computer or reinstall Windows follow the unregister procedure described below:
Unregistering your license
  1. Launch Vizard.
  2. Select the Help > Register Vizard menu option.
  3. Select Unregister License from the register dialog.
  4. Follow the instructions to unregister the license:
  5. A dialog showing that you've successfully unregistered your license will be displayed. Copy the unregister information and send it to license@worldviz.com. Once you've been notified that the license is reset, you can reuse it on another machine:
