Vizard 8 » Reference » Vizard SDK » Using Visual Studio
8.3.1
Using Visual Studio
Vizard is built using the Visual Studio 2019 compiler. All plug-ins must be built with the same compiler in order to properly interface with the Vizard and OpenSceneGraph binaries.
Creating a Visual Studio Project
The first step in creating a plug-in is to create a new Visual Studio 2019 project. Open Visual Studio 2019 and follow these steps:
Once the project is created, you will need to add a class that will be the main interface between your plug-in and Vizard:
Visual Studio Project Settings
Before compiling your project for the first time, you will need to modify some settings in order for your plug-in to work with Vizard.
General:
Output Directory: Set the location you want the compiled plugin to be output
Advanced:
Target File Extension: .dle
C/C++:
General:
Additional Include Directories: Add the location of the Vizard SDK include directory ( /bin/Include ).
Code Generation:
Runtime Library: Multi-threaded DLL
Linker:
General:
Additional Library Directories: Add the location of the Vizard SDK lib directory ( /bin/Libs ).
Input:
Additional Dependencies: Add any OpenSceneGraph libraries your project will be using
Manifest File:
Generate Manifest: No
