Vizard 8 » Reference » Vizard SDK » viz::Extension » update
8.1
viz::Extension::update
Interface
virtual void update(const viz::Event &e);
Description
This method is called at the beginning of every frame. Override this method if your plug-in needs to perform processing at a regular interval. The viz::Event object provides the following methods:
Method
Description
int getID()
Return the current frame number.
Equivalent to viz.getFrameNumber()
double getTime()
Return the current frame time.
Equivalent to viz.getFrameTime()
double getElapsed()
Return the elapsed time since the previous frame.
Equivalent to viz.getFrameElapsed()
Example
void MyExtension::update(const viz::Event &e)
    int frame = e.getID();
    if( frame % 5 == 0 ) {
        //Run some code every 5 frames
