Vizard 8 » Reference » Input Devices » Position and Orientation Trackers » WorldViz PPT
8.3.1
WorldViz PPT plug-in
This plug-in provides support for the WorldViz PPT Wand device.
Initialization
The PPT plug-in is implemented as a Vizard extension, with the following methods/constants:
Method
Description
<ppt>.addWand(port=0)
Add a PPT Wand device on the specified port. If port is 0, then automatically detect the wand on all available ports. A Wand sensor object will be returned.
<ppt>.BUTTON_JOYSTICK
<ppt>.BUTTON_UP
<ppt>.BUTTON_DOWN
<ppt>.BUTTON_LEFT
<ppt>.BUTTON_RIGHT
<ppt>.BUTTON_CENTER
<ppt>.BUTTON_TRIGGER
Button IDs supported by the PPT Wand sensor.
<ppt>.WAND
<ppt>.JOYSTICK
PPT Wand sensor position/rotation flags. The default flag is <ppt>.WAND.
The PPT Wand sensor provides orientation, button, and joystick data. The Wand object contains the following methods, in addition to the standard extension sensor methods:
Method Description
<wand>.getJoystick() Get the joystick [x,y] position which will be in the [-1,1] range. This is a shortcut for calling <wand>.getPosition() with the <ppt>.JOYSTICK flag.
Example
This example shows how to connect to a PPT Wand device on port 1:
# Add PPT extension
ppt = viz.add('ppt.dle')
# Add wand
wand = ppt.addWand(1)
The following code shows how to detect when the trigger button on the Wand is pressed:
import vizact
def onTrigger():
    print('Trigger pressed')
vizact.onsensordown(wand, ppt.BUTTON_TRIGGER, onTrigger)
The PPT Wand sensor also support the vizconfig interface so you can quickly see the button/joystick values:
# Register wand with vizconfig window
import vizconfig
vizconfig.register(wand)
