Vizard 8 » Reference » Stereo & Displays » WorldViz VideoVision
8.3.1
VideoVision is the ultimate solution for affordable and flexible augmented reality applications. See the virtual and the real world simultaneously. Augment your reality with computer generated imagery and animations. Precisely manipulate reality for scientific research applications.
VideoVision includes two separate color cameras with NTSC/PAL output signals, a precision omni mount, hardware-accelerated image acquisition, and a host PC for combining the captured video with computer generated images.
Use the built-in commands in WorldViz' 3D authoring tool Vizard to control the capture, exposure or to buffer up to 20 seconds of video for adding temporal delays. Vizard also makes it extremely easy to add interactive 3D content by importing virtually any 3D file format.
Applications
Augmented reality, mixed reality
Cameras
2x, color, NTSC/PAL stereo
Camera resolution
640 x 480 pixels
FOV (standard)
78 degrees per camera
Eye distance (IPD)
32-107 mm adjustable
Refresh rate
60 Hz
Convergence
Manually adjustable
Focus
Manually adjustable
Iris
Fixed
Electronic shutter time
NTSC 1/60-1/100,000 sec
Weight
230 g
Dimensions (L x W x H)
185mm x 48mm x 47mm
