Vizard 8 » Content Creation » 3D Models » Cal3D Workflow » Building CFG Files
8.3.1
Building CFG Files
CFGs are plain text files that communicate what files make up each avatar. It is the only file that needs to be directly added to Vizard; the rest are loaded based on what is written in the CFG. This section demonstrates the use of CFGs by providing both a simple example and a more complex one. The examples here can be used as templates when making your own CFGs.
CFG Template - Simple Example
Here is an example of an extremely simple CFG file. In this case, the avatar has one mesh with two materials and a couple animations. This level of complexity would be suitable for a simple background character.
Notice that the name of the skeleton appears in the name of each file that relies on it, and that the materials also specify which ID they go with. Neither are necessary for having a Cal3D file work, but following a similar convention is strongly recommended to minimize user error and keep project files organized.
One other thing to note is that the materials are being stored as XRF instead of CRF. This is recommended for materials because each one is just a few lines of XML so storing them as plain text allows for easy editing without any cost to performance.
As with python script, a # sign is used to include comments. In CFG files, comments need to go on their own line.
AdultMale_Worker001.cfg:
# Cal3d cfg File #
# Skeleton #
skeleton = AdultMale.CSF
# Meshes #
mesh = AdultMale_Worker001.CMF
# Materials #
material = AdultMale_Worker001_mat0_Head.XRF
material = AdultMale_Worker001_mat1_Body.XRF
# Animations #
animation = AdultMale_Idle.CAF
animation = AdultMale_Walk.CAF
CFG Template - Complex Example
Here is a more elaborate example. This avatar features:
As with the previous CFG file, the naming convention shows what set of avatars these parts belong to: high poly male avatars.
CC2_m001_hipoly.cfg:
#               Cal3d cfg File                 #
################# Skeleton #####################
skeleton = Skel\CCHD_mHigh_Skeleton.CSF
################# Meshes #######################
mesh = Mesh\CC2_mHigh_m001_head.CMF
morph = Mesh\CC2_mHigh_m001_head_Angry.CMF
morph = Mesh\CC2_mHigh_m001_head_Disgust.CMF
morph = Mesh\CC2_mHigh_m001_head_Sad.CMF
morph = Mesh\CC2_mHigh_m001_head_Smile.CMF
morph = Mesh\CC2_mHigh_m001_head_Surprise.CMF
mesh = Mesh\CC2_mHigh_m001_body.CMF
head_bone = Bip01 Head
neck_bone = Bip01 Neck
jaw_bone = Bip01 MJaw
head_mesh = Mesh\CC2_mHigh_m001_head.CMF
################# Materials ####################
material = Material\CC2_mHigh_m001_mat0_head.XRF
material = Material\CC2_mHigh_m001_mat1_body.XRF
################# Animations ###################
### standing ### 001 - 010
animation = Anim\Standing\CC2_mHigh_m_idle_neutral_01.CAF
animation = Anim\Standing\CC2_mHigh_m_idle_neutral_02.CAF
animation = Anim\Standing\CC2_mHigh_m_idle_drunk_01.CAF
animation = Anim\Standing\CC2_mHigh_m_gestic_talk_neutral_01.CAF
animation = Anim\Standing\CC2_mHigh_m_gestic_listen_neutral_01.CAF
animation = Anim\Standing\CC2_mHigh_m_dancing_neutral_01.CAF
animation = Anim\Standing\CC2_mHigh_m_cell_phone_talk_01.CAF
animation = Anim\CC2_mHigh_PLACEHOLDER.CAF
### walking ### 011 - 015
animation = Anim\Walking\CC2_mHigh_m_walk_neutral_01_inplace.CAF
animation = Anim\Walking\CC2_mHigh_m_walk_drunk_inplace.CAF
### running ### 016 - 020
animation = Anim\Running\CC2_mHigh_m_run_neutral_01_inplace.CAF
animation = Anim\Running\CC2_mHigh_m_run_sprint_01_inplace.CAF
### sit chair ### 021 - 025
animation = Anim\sit_chair\CC2_mHigh_m_sit_chair_idle_neutral_01.CAF
animation = Anim\sit_chair\CC2_mHigh_m_sit_chair_talk_neutral_01.CAF
### sit table ### 026 - 030
animation = Anim\sit_table\CC2_mHigh_m_sit_table_idle_neutral_01.CAF
animation = Anim\sit_table\CC2_mHigh_m_sit_table_talk_neutral_01.CAF
animation = Anim\sit_table\CC2_mHigh_m_sit_table_eat_01.CAF
animation = Anim\sit_table\CC2_mHigh_m_sit_table_drink_01.CAF
### transition ### 031 - 040
animation = Anim\transition\CC2_mHigh_m_sit_down_chair_01.CAF
animation = Anim\transition\CC2_mHigh_m_sit_stand_up_chair_01.CAF
animation = Anim\transition\CC2_mHigh_m_sit_down_table_left.CAF
animation = Anim\transition\CC2_mHigh_m_sit_stand_up_table_left.CAF
animation = Anim\transition\CC2_mHigh_m_sit_down_table_right.CAF
animation = Anim\transition\CC2_mHigh_m_sit_stand_up_table_right.CAF
### execute upperbody ### 040 - 045
animation = Anim\Execute_UpperBody\CC2_mHigh_m_Upperbody_punch.CAF
animation = Anim\Execute_UpperBody\CC2_mHigh_m_Upperbody_wave.CAF
### execute face ###  045 - 055
animation = Anim\Execute_Face\CC2_mHigh_m_Face_talk.CAF
animation = Anim\Execute_Face\CC2_mHigh_m_Face_happy.CAF
animation = Anim\Execute_Face\CC2_mHigh_m_Face_sad.CAF
animation = Anim\Execute_Face\CC2_mHigh_m_Face_angry.CAF
animation = Anim\Execute_Face\CC2_mHigh_m_Face_confused.CAF
Scale
Earlier versions of the Cal3D exporter required scale adjustments to be made in the CFG file. However, in the current version of the exporter this scaling is performed automatically upon export. Please note that new exports are not compatible with old exports without a workaround.
For all but the largest scenes, Max works best with the System Unit set to either centimeters or inches. Note that Max’s System Unit is not the same thing as Max’s Display Unit. It may be tempting to set 3ds Max to 1 unit = 1 meter, since this is what Vizard uses. Unfortunately, this causes some issues to occur in Max. This makes relatively small objects like humans and props difficult to work with.
When the System Unit is set to meters:
It is best to work with 1 unit = 1 cm or 1 unit = 1 inch. Your display units can be whatever you want since these do not affect the actual scale of the model. In current versions of the Cal3D exporter, the model is automatically rescaled to Vizards units regardless of the units used in Max. As long as the model is the correct size in Max (e.g. 6 feet tall), it will appear the correct size in Vizard.
The scale command can still be used to create slight variations on model scale. Just keep in mind that Vizard does not do any retargeting, so this can cause animations that interact with props (e.g. door opening) to miss their targets. To prevent strange behavior, the scale factor should always be specified before the skeleton:
# Cal3d cfg File #
# Skeleton #
scale = 0.01
skeleton = mHigh_Skeleton.CSF
Flip Texture
In earlier versions of the Cal3D exporter, it was sometimes necessary to flip the UVs with a command in the CFG if certain file types were used. This feature is no longer necessary because Vizard now automatically detects when an image that would need to be flipped is used. All images should be stored right-side-up, or in other words, the same way they appear in Max.
There is variation in the order that different image file formats store their data. Some store it starting in the upper left corner, some in the bottom left. Cal3D does not currently make assumptions about the data order, so flip_texture is often used to make sure that maps come in with the correct orientation. Typically, formats like JPG, TGA and PNG need to be flipped, while DDS does not. If your texture appears to be coming in upside down compared to the max model, adding a flip_texture line is the first thing to try. If you open an older file and the texture appears upside down, someone may have tried to correct the flipping by editing the image itself.
# Cal3d cfg File #
flip_texture = 1
# Skeleton #
