Vizard 8 » Reference » Graphical user interfaces (GUIs) » Dialog boxes » vizinput properties
8.3.1
vizinput properties
Changing the title, parent, and position of a dialog
All vizinput dialog objects accept the same optional keyword arguments for changing their title, parent object, and position. The following table lists these arguments and their default values:
Argument
Description
title = 'Vizard'
A string value that is displayed in the upper left corner of the dialog.
parent = viz.window.getHandle()
This can either be the Vizard graphics window or the desktop. By default it is set to the Vizard graphics window. When parenting to the desktop set this argument to 0
center = vizinput.CENTER
Sets the dialog's position in relation to the parent object. See the table below for a list of available flags.
pos = None
This will set the x and y position of the dialog in pixel coordinates, where (0,0) is the upper left corner of the monitor. If a value is given here, the center argument will be ignored.
The following flags and combinations of flags can be used with the center argument:
Flag
vizinput.CENTER
vizinput.CENTER_LEFT
vizinput.CENTER_RIGHT
vizinput.CENTER_TOP
vizinput.CENTER_BOTTOM
vizinput.CENTER_LEFT|vizinput.CENTER_TOP
vizinput.CENTER_RIGHT|vizinput.CENTER_TOP
vizinput.CENTER_LEFT|vizinput.CENTER_BOTTOM
vizinput.CENTER_RIGHT|vizinput.CENTER_BOTTOM
Example
import vizinput
vizinput.message('Parented to the Vizard Window, top center',center=vizinput.CENTER_TOP)
vizinput.message('Parented to the Desktop, top center',parent=0,center=vizinput.CENTER_TOP)
vizinput.message('Positioned using pixel coordinates',pos=[50,50])
vizinput.message('A different title', title='myApp')
Changing default properties
The vizinput module provides commands to change the title, parent, and center defaults. This is useful when you need to make a change to multiple dialogs. Instead of using a keyword argument each time one is created, the default command is called once and is applied to all dialogs that follow:
Command
Description
vizinput.setDefaultTitle(title)
title: A string that sets the default title.
vizinput.setDefaultParent(parent)
parent: Sets the default parent object. Use 0 to parent to the desktop and viz.window.getHandle() to parent to the Vizard graphics window
vizinput.setDefaultCenter(center)
center: Sets the default center.
Example
The following example sets new center and title defaults:
import vizinput
#Set new default center
vizinput.setDefaultCenter(vizinput.CENTER_BOTTOM)
vizinput.message('New default center')
vizinput.color(viz.RED)
#Set new default title
vizinput.setDefaultTitle('MyApp')
vizinput.message('New default title')
vizinput.choose('select...',['1','2','3'])
vizinput dialogs
vizinput properties
