Vizard 8 » Reference » Stereo & Displays » Display devices » Windows Mixed Reality HMDs
8.3.1
Windows Mixed Reality Headsets
Vizard supports Windows Mixed Reality headsets via SteamVR. Install the Windows Mixed Reality for SteamVR app and then connect to the headset using Vizard's SteamVR plug-in. The recommended way to connect to the headset and hand controllers is by using the Windows Mixed Reality preset configuration in vizconnect.
Note: The hand controllers are accessed using the steamvr.getControllerList() command. The hand order, however, in the list returned is not consistent between Vizard runs. To account for this, it is recommended that a function is added in the code to swap the links between hand models and controllers on the fly.
