Vizard 7 » Reference » Shaders » Post-Process Effects » Transform effects
7.6
Transform effects
The vizfx.postprocess.transform library is a collection of effects that perform various transformations on the rendered image.
Flip
Flips the image horizontally and/or vertically.
Constructor
Description
FlipEffect(
    horizontal = False,
    vertical = False
Create the flip effect with the initial horizontal and vertical flip flags.
Method
Description
<effect>.setFlipHorizontal(flip)
Set whether to flip image horizontally.
<effect>.getFlipHorizontal()
Get if image is flipped horizontally.
<effect>.setFlipVertical(flip)
Set whether to flip image vertically.
<effect>.getFlipVertical()
Get if image is flipped vertically.
This effect can be registered with vizconfig.
import vizfx.postprocess
from vizfx.postprocess.transform import FlipEffect
effect = FlipEffect(horizontal=True)
vizfx.postprocess.addEffect(effect)
Translate
Translate the image.
Constructor
Description
TranslateEffect(
    translate = (0.0,0.0),
    repeat = False
Create the translate effect with the initial translate offset and repeat flag.
Method
Description
<effect>.setTranslate(value)
Set the [x,y] translation in normalized (0-1) units.
<effect>.getTranslate()
Get the [x,y] translation in normalized (0-1) units.
<effect>.setRepeat(value)
Set whether to repeat the image when UV coordinates are outside (0-1) range.
<effect>.getRepeat()
Get whether to repeat the image when UV coordinates are outside (0-1) range.
from vizfx.postprocess.transform import TranslateEffect
effect = TranslateEffect(translate=(0.25,0.25))
Rotate
Rotate the image about a specified center.
Constructor
Description
RotateEffect(
    angle = 0.0,
    center = (0.5,0.5),
    repeat = False
Create the rotate effect with the initial rotation angle, center, and repeat flag.
Method
Description
<effect>.setAngle(value)
Set the rotation angle, in degrees. Positive angles rotate clockwise.
<effect>.getAngle()
Get the rotation angle, in degrees.
<effect>.setCenter(value)
Set the [x,y] center to rotate about, in normalized (0-1) units.
<effect>.getCenter()
Get the [x,y] center to rotate about, in normalized (0-1) units.
from vizfx.postprocess.transform import RotateEffect
effect = RotateEffect(angle=45)
Scale
Scale the image about a specified center.
Constructor
Description
ScaleEffect(
    scale = (1.0,1.0),
    center = (0.5,0.5),
    repeat = False
Create the scale effect with the initial scale factor, center, and repeat flag.
Method
Description
<effect>.setScale(value)
Set the [x,y] scale factor.
<effect>.getScale()
Get the [x,y] scale factor.
Set the [x,y] center to scale about, in normalized (0-1) units.
Get the [x,y] center to scale about, in normalized (0-1) units.
from vizfx.postprocess.transform import ScaleEffect
effect = ScaleEffect(scale=(0.5,0.5))
Post-Process Basics
Color Effects
Distort Effects
Blur Effects
Transform Effects
Composite Effects
