A Vizard program can create multiple scenes, each with its own set of objects. When multiple scenes have been created, you can flip back and forth between them by setting the scene that's currently being renderer. By default things are added to the first scene (scene 1). You need to use viz.addScene if you want more than the default 6 scenes.
#Add an object to scene 1.
duck = viz.add('duck.wrl', viz.WORLD, 1)
duck.setPosition(1,1,5)
#Add an object to scene 2.
wheelbarrow = viz.add('wheelbarrow.ive', viz.WORLD, 2)
wheelbarrow.setPosition(-1,1,5)
#Add keypresses to change between scenes 1 and 2.
vizact.onkeydown( '1', viz.scene, 1 )
vizact.onkeydown( '2', viz.scene, 2 )
You can copy, duplicate or clone an object to a different scene. The duplicate of an object (<node3d>.addParent(<parent>,<scene>)) will appear in the specified scene. Any transforms or changes in appearance to the original object will also be applied to the duplicate. If you copy an object to another scene, the copy ((<node3d>.copy()) will have the appearance of the original object when it was created but any subsequent changes to the original object's appearance will not effect the copy in the other scene. Copies are created independent of any position, orientation or scale transforms applied to the original object. So, even if you create a copy of an object that's 2 meters about the origin, the copy will appear at the origin. Clones (<node3d>.clone()) share the appearance of each other such that changing the appearance to any one clone will change the appearance of all the clones (although all their position, orientation, and scale transforms will be independent).
You can also use different subwindows to render different scenes.
#Set the main window's scene to 2.
viz.scene( 2
#Add a subwindow set on scene 1.
duckWindow = viz.addWindow()
duckView = viz.addView()
duckView.setScene(1)
duckWindow.setView(duckView)
