Vizard 8 » Reference » 3D models » Creating 3D models on-the-fly » Creating 3D models on-the-fly--the basics
8.3.1
Creating 3D models on-the-fly basics
Vizard allows you to create basic geometric objects "on-the-fly". These objects are defined by creating vertices and then connecting those vertices with lines or surfaces. Once you've created an on-the-fly object, you can treat it as you would any other 3D object. You can also access individual vertices and manipulate them independently of the rest of the objects.
Each object you create is defined by a layer of vertices. A layer can be a set of points, lines, triangles, quadrilaterals, or polygons. Your options for kinds of layers are listed in the table below.
Type flag
Description
viz.POINTS
Creates a point for each vertex in the list.
viz.LINES
Creates a series of separate lines by splitting the list of vertices into pairs and drawing a line between each member in each pair.
viz.LINE_STRIP
Creates a series of connected lines by drawing a line between each vertex and the next vertex in the list.
viz.LINE_LOOP
Creates a loop of lines by drawing a line between each vertex and the next vertex on the list, and then connecting the last vertex with the first vertex on the list.
viz.TRIANGLES
Creates a series of separate triangular surfaces. The list of vertices is split into sets of three which each define a separate triangle.
viz.TRIANGLE_STRIP
Creates an series of triangular surfaces connected along shared edges.  Each contiguous trio of vertices defines a triangle in the strip.
viz.TRIANGLE_FAN
Creates a fan of triangular surfaces. The first vertex is linked to each subsequent pair of vertices tp define each triangle in the fan.
viz.QUADS
Creates a series of separate quadrilateral surfaces. The list of vertices is split into sets of four which each define a separate quadrilateral.
viz.QUAD_STRIP
Creates a series of quadrilateral surfaces connected along shared edges. Each contiguous series of four vertices defines a quadrilateral in the strip.
viz.POLYGON
Creates a polygon. Each vertex provides a point for the polygon. Each of the inside angles created by linking the vertices must be acute.
#Example for creating a set of points:
viz.startLayer(viz.POINTS)
viz.vertex(-.5,1,5)
viz.vertex(-.5,2,5)
viz.vertex(.5,1,5)
viz.vertex(.5,2,5)
viz.vertex(0,1.5,5)
myPoints = viz.endLayer()
#Example for creating a set of lines:
viz.startLayer(viz.LINES)
viz.vertex(-1,1,5) #Vertices are split into pairs.
viz.vertex(-1,2,5)
viz.vertex(0,2,5)
viz.vertex(0,1,5)
viz.vertex(1,1,5)
viz.vertex(1,2,5)
myLines = viz.endLayer()
#Example for creating a set of quadrilaterals:
viz.startLayer(viz.QUADS)
viz.vertex(-2.25,1,5) #Vertices are split into sets of four.
viz.vertex(-2.25,2,5)
viz.vertex(-1,3,5)
viz.vertex(-1,1,5)
viz.vertex(1.,0,5)
viz.vertex(1.,2,5)
viz.vertex(2.25,2,5)
viz.vertex(2.25,1,5)
myQuad = viz.endLayer()
#Example for creating a fan of triangles:
viz.startLayer(viz.TRIANGLE_FAN)
viz.vertex(0,1,5) #All the triangles have the first vertex as a point.
viz.vertex(-1.5,1.35,10) #The other points are taken in pairs.
viz.vertex(-.25,1.5,10)
viz.vertex(0,.8,10)
viz.vertex(.25,1.5,10)
viz.vertex(1.5,1.35,10)
myTrianglefan = viz.endLayer()
See also
In this section:
Vertex properties
Changing vertices on-the-fly
Creating models on-the-fly command table
Other sections:
3D model transform basics
Tutorial: On-the-fly objects
Example scripts:
3D objects on-the-fly
