Vizard 8 » Reference » Events » Event reference
8.3
Event Reference
The following page contains a description of all the core Vizard events. Here is an overview of the available events:
Event code
Description
viz.KEYDOWN_EVENT
A key is pressed
viz.KEYUP_EVENT
A key is released
viz.KEY_CHAR_EVENT
A keyboard character as been entered
viz.MOUSEDOWN_EVENT
A mouse button is pressed
viz.MOUSEUP_EVENT
A mouse button is released
viz.MOUSEWHEEL_EVENT
The mouse wheel is scrolled
viz.MOUSE_MOVE_EVENT
The mouse has moved
viz.DOUBLE_CLICK_EVENT
A mouse button is double clicked
viz.INIT_EVENT
The graphics window is initialized
viz.EXIT_EVENT
The program is exiting
viz.TIMER_EVENT
A timer has expired
viz.BUTTON_EVENT
A GUI object has changed state
viz.SLIDER_EVENT
A GUI slider has been dragged
viz.TEXTBOX_EVENT
A key was pressed in a GUI textbox
viz.LIST_EVENT
A GUI droplist selection has changed
viz.COLLISION_EVENT
The viewpoint has collided into an object
viz.UPDATE_EVENT
Called every frame
viz.NETWORK_EVENT
Received a network message
viz.WINDOW_SIZE_EVENT
Graphics window has been resized
viz.ANIMATION_END_EVENT
Avatar animation has completed
viz.POST_SWAP_EVENT
A frame has rendered to the display
viz.COLLIDE_BEGIN_EVENT
Two physics objects have collided
viz.COLLIDE_END_EVENT
Two physics objects have finished colliding
viz.ACTION_BEGIN_EVENT
An action has started executing
viz.ACTION_END_EVENT
An action has finished executing
viz.ACTION_EMPTY_EVENT
An action pool has run out of actions
viz.MEDIA_EVENT
Special events for audio/video objects
viz.SENSOR_DOWN_EVENT
Sensor button has been pressed
viz.SENSOR_UP_EVENT
Sensor button has been released
viz.ASYNC_EVENT An async operation has completed
viz.PATH_EVENT An animation path event has been triggered
viz.KEYDOWN_EVENT
This event is generated when a key is pressed. If the key is held down, multiple keydown events will be generated. The viz.getInputTime() command can be used with key down events.
Parameters
key
The character or code of the key that was pressed. Click here for a list of keyboard codes.
Example
def onKeyDown(key):
    if key == ' ':
        print('Space key pressed')
    elif key == viz.KEY_UP:
        print('Up arrow pressed')
viz.KEYUP_EVENT
This event is generated when a key is released. The viz.getInputTime() command can be used with key up events.
Parameters
key
The character or code of the key that was released. Click here for a list of keyboard codes.
Example
def onKeyUp(key):
    if key == 'q':
        print('q key released')
    elif key == viz.KEY_HOME:
        print('Home key released')
viz.callback(viz.KEYUP_EVENT,onKeyUp)
viz.KEY_CHAR_EVENT
This event is generated when a displayable character is entered through the keyboard.  The viz.getInputTime() command can be used with key character events.
Parameters
This event provides a single event structure e with the following attributes:
e.char
A unicode string containing the single character that was entered.
e.time
The input time of the event. Same as the value returned by viz.getInputTime().
Example
def onKeyChar(e):
    print('Key Char:')
    print('  time:',e.time)
    print('  char:',e.char)
viz.callback(viz.KEY_CHAR_EVENT,onKeyChar)
viz.MOUSEDOWN_EVENT
This event is generated when a mouse button is pressed. The viz.getInputTime() command can be used with mouse down events.
Parameters
button
The mouse button that was pressed. Can be one of the following mouse button codes:
Mouse buttons
viz.MOUSEBUTTON_LEFT
viz.MOUSEBUTTON_MIDDLE
viz.MOUSEBUTTON_RIGHT
Example
def onMouseDown(button):
    if button == viz.MOUSEBUTTON_LEFT:
        print('Left button pressed')
viz.callback(viz.MOUSEDOWN_EVENT,onMouseDown)
viz.MOUSEUP_EVENT
This event is generated when a mouse button is released. The viz.getInputTime() command can be used with mouse up events.
Parameters
button
The mouse button that was released. Can be one of the following mouse button codes:
Mouse buttons
Example
def onMouseUp(button):
    if button == viz.MOUSEBUTTON_RIGHT:
        print('Right button released')
viz.callback(viz.MOUSEUP_EVENT,onMouseUp)
This event is generated when a mouse wheel is scrolled. The viz.getInputTime() command can be used with mouse wheel events.
Parameters
dir
The direction the mouse wheel was scrolled. A value greater than zero indicates the mouse wheel was scrolled upwards. A value less than zero indicates the mouse wheel was scrolled downwards.
Example
def onMouseWheel(dir):
    if dir > 0:
        print('Mouse wheel scrolled up')
        print('Mouse wheel scrolled down')
viz.callback(viz.MOUSEWHEEL_EVENT,onMouseWheel)
This event is generated when the mouse is moved. The viz.getInputTime() command can be used with mouse move events. The event provides the absolute position of the mouse normalized to the graphics window and the relative movement of the mouse. The absolute position is not updated when the mouse leaves the graphics window, however the event will still be generated in order to provide the relative movement.
Parameters
e.x
The absolute X position of the mouse relative to the left side of the graphics window. The value is in the range [0,1].
e.y
The absolute Y position of the mouse relative to the bottom of the graphics window. The value is in the range [0,1].
e.dx
The relative movement of the mouse in the X direction. The value is in raw mouse units. Negative values indicate the mouse was moved to the left. Positive values indicate the mouse was moved to the right.
e.dy
The relative movement of the mouse in the Y direction. The value is in raw mouse units. Negative values indicate the mouse was moved downward. Positive values indicate the mouse was moved upward.
Example
def onMouseMove(e):
    print('Relative movement:',e.dx,e.dy)
viz.callback(viz.MOUSE_MOVE_EVENT,onMouseMove)
This event is generated when a mouse button is double clicked. The viz.getInputTime() command can be used with double click events.
Parameters
e.button
The mouse button that was double clicked. Can be one of the following mouse button codes:
Mouse buttons
Example
def onDoubleClick(e):
    if e.button == viz.MOUSEBUTTON_LEFT:
        print('Left button double clicked')
viz.callback(viz.DOUBLE_CLICK_EVENT,onDoubleClick)
viz.INIT_EVENT
This event is generated when the graphics window is initialized (i.e. after viz.go() is called).
Parameters
None
Example
def onInit():
    print('window initialized')
viz.callback(viz.INIT_EVENT,onInit)
viz.EXIT_EVENT
This event is generated when the simulation exits.
Parameters
None
Example
def onExit():
    import vizinput
    vizinput.message('goodbye')
viz.callback(viz.EXIT_EVENT,onExit)
viz.TIMER_EVENT
This event is generated when a timer expires. The viz.elapsed() command can be used with timer events.
Parameters
num
The timer number that expired.
Example
def onTimer(num):
    print('Timer id',num,'expired')
viz.callback(viz.TIMER_EVENT,onTimer)
viz.starttimer(0,1,viz.FOREVER)
viz.BUTTON_EVENT
This event is generated when a GUI button has changed state. This event is also used by other GUI objects to signal state changes.
Parameters
obj
The node3d object that has changed state.
state
The new state of the object. Can be one of the following values:
Button States
viz.DOWN
Signals one of the following:
  • A button has been pressed
  • A checkbox has been checked
  • A radio button has been selected
  • A slider has started dragging
  • A textbox has entered input focus
  • A droplist has entered selection focus
viz.UP
  • A button has been released
  • A checkbox has been unchecked
  • A slider has stopped dragging
  • A textbox has exited input focus
  • A droplist has exited selection focus
Example
checkbox = viz.addCheckbox(pos=(0.5,0.5,0))
def onButton(obj,state):
    if obj == checkbox:
        if state == viz.DOWN:
            print('Checked')
            print('Unchecked')
viz.callback(viz.BUTTON_EVENT,onButton)
viz.SLIDER_EVENT
This event is generated when the value of GUI slider or progress bar has been changed by the user. This event is NOT generated if the value is manually modified through code.
Parameters
obj
The slider or progress bar object that has changed value.
pos
The new value of the slider. The value is in the range [0,1].
Example
slider = viz.addSlider(pos=(0.5,0.5,0))
def onSlider(obj,pos):
    if obj == slider:
        print('Slider value',pos)
viz.callback(viz.SLIDER_EVENT,onSlider)
viz.TEXTBOX_EVENT
This event is generated when a key has been pressed inside a GUI textbox. This event will be generated even if the actual text was not modified.
Parameters
e.object
The textbox object generating the event.
e.oldText
The textbox value before the key was pressed.
e.newText
The textbox value after the key was pressed.
e.key
Example
textbox = viz.addTextbox(pos=(0.5,0.5,0))
def onTextbox(e):
    if e.object == textbox:
        print('New text:',e.newText)
viz.callback(viz.TEXTBOX_EVENT,onTextbox)
viz.LIST_EVENT
This event is generated when the selected item of a GUI droplist or tab group has changed.
Parameters
e.object
The object generating the event.
e.oldSel
The zero-based index of the previously selected item.
e.newSel
The zero-based index of the newly selected item.
Example
droplist = viz.addDropList(pos=(0.5,0.5,0))
droplist.addItems(['item 1','item 2','item 3'])
def onList(e):
    if e.object == droplist:
        print('Droplist selection',e.newSel)
viz.callback(viz.LIST_EVENT,onList)
viz.COLLISION_EVENT
This event is generated when the viewpoint collides with an object. Viewpoint collision must be enabled for the event to be generated.
Parameters
info
An intersect info object containing details of the collision. The object has the following attributes:
Attribute name
Description
object
node3d object the viewpoint collided with
point
[x,y,z] position of collision
normal
[x,y,z] normal vector of collision point
name
Name of sub-node involved in collision
Example
def onCollision(info):
    print('Collided with object',info.object)
viz.callback(viz.COLLISION_EVENT, onCollision)
viz.UPDATE_EVENT
This event is generated during the update cycle of every frame. The viz.elapsed() command can be used with update events.
Parameters
e.elapsed
The elapsed time (in seconds) since the last frame. Same as the value returned by viz.getFrameElapsed()
e.frame
The frame number of the new frame. Same as the value returned by viz.getFrameNumber()
e.time
The start time of the new frame (in seconds) relative to the start of the main graphics loop. Same as the value returned by viz.getFrameTime()
Example
def onUpdate(e):
    print('Updating frame',e.frame)
viz.callback(viz.UPDATE_EVENT,onUpdate)
viz.NETWORK_EVENT
This event is generated when Vizard receives a network message.
Parameters
This event provides a single event structure e. It can be either a viz.NetworkEvent or viz.RawNetworkEvent object.
viz.NetworkEvent
A viz.NetworkEvent object will be passed to the callback function if the data received was encoded using the Python pickle module. This applies to data that was:
The event stucture e has the following attributes:
Event attribute
Description
sender
The name of the computer that sent the message.
address
The IP address of the computer that sent the message.
port
The port number the message was received on.
data
A tuple containing the positional data specified through the *args parameter.
<keyword>
The value of the specified keyword argument from the **kwargs parameter.
viz.RawNetworkEvent
A viz.RawNetworkEvent object will be passed to the callback function when a raw byte network packet is received. This is useful for receiving data from non-Python based applications. The event stucture e has the following attributes:
Event attribute
Description
address
port
raw_data
The raw byte data that was received, as a Python bytes object.
Example
network = viz.addNetwork('localhost')
def onKeyDown(key):
    if key == ' ':
        network.send(1,2,3,foo=4,bar=5)
def onNetwork(e):
    print('Positional data:',e.data)
    print(e.foo,e.bar)
viz.callback(viz.NETWORK_EVENT,onNetwork)
This event is generated when the Vizard graphics window is resized. This event will be triggered before the first frame is rendered and when the window is resized manually through code.
Parameters
e.width
The new width of the graphics window.
e.height
The new height of the graphics window.
Example
def onWindowSize(e):
    print('New size',e.width,e.height)
viz.callback(viz.WINDOW_SIZE_EVENT,onWindowSize)
This event is generated when an avatar finishes executing an animation.
Parameters
e.object
The avatar object generating the event.
e.animation
The animation number that has finished executing.
e.userTriggered
Indicates whether the user triggered the end of the animation manually through code (i.e. the <node3d:avatar>.stopAction() command) . Can be either True or False.
Example
male = viz.add('vcc_male.cfg',pos=(0,0,5),euler=(180,0,0))
male.execute(2)
def onAnimationEnd(e):
    if e.object == male:
        print('Animation ended',e.animation)
viz.callback(viz.ANIMATION_END_EVENT,onAnimationEnd)
viz.POST_SWAP_EVENT
This event is generated when a frame has finished being rendered and has been displayed on screen. When a user registers a callback for this event, Vizard will block at the end of the frame until the frame buffer has been copied to the screen.
Parameters
e.time
The time of the frame display. The time value is relative to the viz.tick() command.
Example
def onPostSwap(e):
    print('Frame display time',e.time)
viz.callback(viz.POST_SWAP_EVENT,onPostSwap)
This event is generated when two physics objects collide. To be notified of physics collisions you need to first enable the viz.COLLIDE_NOTIFY flag on the node. If two objects that have collision notification enabled collide, two separate events will be generated.
Parameters
e.obj1
The first object in the collision. This is the object which has collision notification enabled.
e.obj2
The second object in the collision.
e.pos
The [x,y,z] position of the collision point.
e.normal
The [x,y,z] normal vector of the collision point.
Example
def onCollideBegin(e):
    print('Objects collided',e.obj1,e.obj2)
viz.callback(viz.COLLIDE_BEGIN_EVENT,onCollideBegin)
This event is generated when two physics objects finish colliding. To be notified of physics collisions you need to first enable the viz.COLLIDE_NOTIFY flag on the node. If two objects that have collision notification enabled collide, two separate events will be generated.
Parameters
e.obj1
e.obj2
Example
def onCollideEnd(e):
    print('Finished colliding',e.obj1,e.obj2)
viz.callback(viz.COLLIDE_END_EVENT,onCollideEnd)
This event is generated when an action has started on an object.
Parameters
e.object
e.action
The action object that has started executing. An instance of viz.ActionData.
e.pool
The pool number the action has started on.
e.instance
The viz.ActionClass instance of the action object.
Example
spin = vizact.spin(0,1,0,90,1)
ball = viz.add('ball.wrl',pos=(0,1.8,2))
ball.addAction(vizact.waittime(1))
ball.addAction(spin)
def onActionBegin(e):
    if e.object is ball and e.action is spin:
        print('Ball started spinning')
viz.callback(viz.ACTION_BEGIN_EVENT,onActionBegin)
This event is generated when an action is completed on an object. The event will occur even if the action is manually completed by the user through code (i.e. the <node3d>.endAction() command).
Parameters
e.object
e.action
The action object that has finished completing. An instance of viz.ActionData.
e.pool
The pool number the action has completed on.
e.instance
Example
ball.runAction(spin)
def onActionEnd(e):
        print('Ball finished spinning')
viz.callback(viz.ACTION_END_EVENT,onActionEnd)
This event is generated when an action pool runs out of actions to execute.
Parameters
e.object
e.pool
The pool number that has run out of actions.
Example
ball.addAction(vizact.spin(0,1,0,90,1))
def onActionEmpty(e):
    if e.object is ball:
        print('No more actions for ball :(')
viz.callback(viz.ACTION_EMPTY_EVENT,onActionEmpty)
viz.MEDIA_EVENT
This event is generated when a media object enters certain states.
Parameters
e.object
The media object generating the event.
e.event
The event that occurred on the media object. Can be one of the following values:
Event code
Description
viz.MEDIA_END
The media object has reached the end
Example
sound = viz.add('boing!.wav')
sound.play()
def onMedia(e):
    if e.object is sound and e.event == viz.MEDIA_END:
        print('sound ended')
viz.callback(viz.MEDIA_EVENT,onMedia)
This event is generated when a sensor button is pressed.
Parameters
e.object
The extension sensor object generating the event.
e.button
ID of the sensor button that was pressed.
Example
#Create vrpn extension
vrpn = viz.add('vrpn7.dle')
#Add button object at specified address
button = vrpn.addButton('Joystick0@localhost')
#Register a callback for button down event
def onButtonDown(e):
    if e.object is button:
        print('button',e.button,'down')
viz.callback(viz.SENSOR_DOWN_EVENT,onButtonDown)
viz.SENSOR_UP_EVENT
This event is generated when a sensor button is released.
Parameters
e.object
e.button
ID of the sensor button that was released.
Example
#Register a callback for button up event
def onButtonUp(e):
        print('button',e.button,'up')
viz.callback(viz.SENSOR_UP_EVENT,onButtonUp)
viz.ASYNC_EVENT
This event is generated when an async operation has completed.
Parameters
e.object
e.status
The status of the async operation ( viz.ASYNC_SUCCESS or viz.ASYNC_FAIL ).
Example
model = viz.addChild('piazza.osgb', flags=viz.LOAD_ASYNC)
def onAsync(e):
    if e.object is model:
        if e.status == viz.ASYNC_SUCCESS:
            print('Model loaded successfully')
            print('Model failed to load')
viz.callback(viz.ASYNC_EVENT, onAsync)
viz.PATH_EVENT
This event is generated when a user specific animation path event has been triggered.
Parameters
e.object
The animation path object generating the event
e.name
The user specified name of the event trigger
e.time
The time within the path the event was scheduled to trigger
Example
# Create path
path = viz.addAnimationPath()
# Add event when end is reached
path.addEventAtEnd('finished')
# Add event at second control point
path.addEventAtControlPoint('point 2', 1)
# Register callback for path event
def onPathEvent(e):
    if e.object is path:
        print(e.name)
viz.callback(viz.PATH_EVENT, onPathEvent)
See also
In this section:
Event Basics
Custom Events
Other sections:
Action basics
Task basics
Director basics
Timer basics
Example scripts:
Event callbacks
Event handling
Event class timer
