Vizard 8 » Tutorials & Examples » Getting your feet wet » Moving the Viewpoint
8.3.1
Tutorial: Moving the viewpoint
It's often useful to move the viewpoint manually. For example, we may want the starting position to be in the cafe or up in a balcony looking down on the courtyard. To get a handle to the viewpoint use viz.MainView.
Viewpoint position
To move the viewpoint relative to it's current position use the  viewpoint.move  command. The following code will move the viewpoint right 3 meters (+ X direction), back 7 meters (- Z direction) and leave the height (Y direction) unchanged:
viz.MainView.move([3,0,-7])
Run the script and see how the viewpoint position has changed. The new location is [3,1.8,-7] in world coordinates. This is the result of adding [3,0,-7] to the initial position, [0,1.8,0].
To place the viewpoint in world coordinates use the viewpoint.setPosition command. Add the following line to move the viewpoint 15 meters up ( + Y direction ) and 15 meters back ( -Z direction) from the origin:
viz.MainView.setPosition([0,15,-15])
Run the script and you'll find yourself above the ground and towards the back of the courtyard.
Viewpoint orientation
To change viewpoint orientation use the viewpoint.setEuler command. This command takes a list of yaw, pitch, and roll values. Yaw specifies the rotation around the Y-axis , pitch specifies the rotation around the X-axis, and roll specifies the rotation around the Z-axis. Images B-D below illustrate the effect of rotation around the different axes.
A. Initial viewpoint orientation  (yaw=0,pitch=0,roll=0)
B. Change in viewpoint yaw     (yaw=30,pitch=0,roll=0)
C. Change in viewpoint pitch   (yaw=0,pitch=30,roll=0)
D. Change in viewpoint roll      (yaw=0,pitch=0,roll=30)
Add the following line of code to give the feeling you're looking down on the courtyard from one of the balconies and run the script.
viz.MainView.setEuler([0,30,0])
Exercise: Aerial view of the piazza: Change the setPosition and setEuler values from the last two lines of codes so that you're 20 meters directly above the origin looking down.
Launch into a new world
Creating a new Script
Setting the Scene
Manipulating 3D Models
Animating 3D Models
Timer Events
Adding Avatars
Inserting User Interaction
