Vizard 8 » Reference » Graphical user interfaces (GUIs) » Organizing GUIs » vizdlg introduction
8.3.1
vizdlg introduction
Use the vizdlg library to add panels with GUIs and dialog objects to the screen:
Dialog objects are panels with accept/cancel buttons:
Example
The following example code shows how to create a simple Panel object with several GUI elements:
import vizdlg
myPanel = vizdlg.Panel()
myPanel.addItem(viz.addText('A simple panel'),align=vizdlg.ALIGN_CENTER)
myPanel.addItem(viz.addCheckbox())
myPanel.addItem(viz.addSlider())
myPanel.addItem(viz.addTextbox())
viz.link(viz.CenterCenter,myPanel,offset=(-100,50,0))
The image below shows a TabPanel with a TickerDialog in the active tab:
The following code creates the panel above:
import viz
import vizdlg
p1 = vizdlg.TickerDialog(label='Circle',units='pixels',range=(1,5,1),editable=True,border=False,background=False,margin=0)
p2 = vizdlg.TickerDialog(label='Crosshair',units='pixels',range=(1,5,1),editable=True,border=False,background=False,margin=0)
p3 = vizdlg.TickerDialog(label='Border',units='pixels',range=(1,5,1),editable=True,border=False,background=False,margin=0)
tp = vizdlg.TabPanel(align=vizdlg.ALIGN_RIGHT_TOP)
tp.addPanel('Circle',p1,align=vizdlg.ALIGN_LEFT_TOP)
tp.addPanel('Crosshair',p2,align=vizdlg.ALIGN_CENTER_TOP)
tp.addPanel('Border.',p3,align=vizdlg.ALIGN_RIGHT_TOP)
tp.addPanel('checkbox',viz.addCheckbox(),align=vizdlg.ALIGN_LEFT_BOTTOM)
tp.addPanel('slider',viz.addSlider(),align=vizdlg.ALIGN_CENTER_BOTTOM)
tp.addPanel('movie',viz.addTexQuad(size=75,texture=viz.add('vizard.mpg',loop=True,play=True)),align=vizdlg.ALIGN_RIGHT_BOTTOM)
viz.link(viz.RightTop,tp,offset=(-20,-20,0))
vizdlg introduction
vizdlg panels
vizdlg dialog components
vizdlg advanced
