Vizard 8 » Tutorials & Examples » Python Programming » Addons » ReportLab
8.3.1
ReportLab
The ReportLab Toolkit allows you to create PDF files within Python. There is a library of functions to create your document using headlines, paragraphs, fonts, tables, charts, etc.
Installation
From the Tools menu, open the Package Manager. Use the Search tab to locate the libraries and click Install.
Documentation
For documentation and example code, take a look at the user guide on the ReportLab documentation page.
Example
The following script creates a PDF file and displays data in a paragraph, table, and chart:
from reportlab.pdfgen.canvas import Canvas
from reportlab.lib.pagesizes import letter
from reportlab.lib.styles import getSampleStyleSheet
from reportlab.lib.units import inch
from reportlab.lib import colors
from reportlab.platypus import Paragraph, Frame, Spacer, Image, Table, TableStyle, SimpleDocTemplate
from reportlab.graphics.charts.barcharts import VerticalBarChart
from reportlab.graphics.shapes import Drawing#, string
from reportlab.graphics.charts.textlabels import Label
from reportlab.graphics.charts.legends import Legend
#This is your data collected from your Vizard experiment
subject1 = 'Tom'
subject2 = 'Ana'
results1 = [15,23,42,56,76]
results2 = [34,67,94,31,56]
#take the data and make ready for paragraph
def dataToParagraph(name, data):
    p = '<strong>Subject name: </strong>' + name + '<br/>' + '<strong>Data: </strong>  ('
    for i in range(len(data)):
        p += str(data[i])
        if i != len(data) - 1:
            p += ', '
            p += ')'
    return p
#take the data and convert to list of strings ready for table
def dataToTable(name, data):
    data = [str(x) for x in data]
    data.insert(0,name)
    return data
#create the table for our document
def myTable(tabledata):
    #first define column and row size
    colwidths = (70, 50, 50, 50, 50, 50)
    rowheights = (25, 20, 20)
    t = Table(tabledata, colwidths, rowheights)
    GRID_STYLE = TableStyle(
    [('GRID', (0,0), (-1,-1), 0.25, colors.black),
    ('ALIGN', (1,1), (-1,-1), 'RIGHT')]
    t.setStyle(GRID_STYLE)
    return t
#create a bar chart and specify positions, sizes, and colors
def myBarChart(data):
    drawing = Drawing(400, 200)
    bc = VerticalBarChart()
    bc.= 50
    bc.= 50
    bc.height = 125
    bc.width = 300
    bc.data = data
    bc.barWidth = .3*inch
    bc.groupSpacing = .2 * inch
    bc.strokeColor = colors.black
    bc.valueAxis.valueMin = 0
    bc.valueAxis.valueMax = 100
    bc.valueAxis.valueStep = 10
    bc.categoryAxis.labels.boxAnchor = 'ne'
    bc.categoryAxis.labels.dx = 8
    bc.categoryAxis.labels.dy = -2
    catNames = ('Trial1 Trial2 Trial3 Trial4 Trial5').split()
    bc.categoryAxis.categoryNames = catNames
    bc.bars[0].fillColor = colors.blue
    bc.bars[1].fillColor = colors.lightblue
    drawing.add(bc)
    return drawing
#add a legend for the bar chart
def myBarLegend(drawing, name1, name2):
    "Add sample swatches to a diagram."
    d = drawing or Drawing(400, 200)
    swatches = Legend()
    swatches.alignment = 'right'
    swatches.= 80
    swatches.= 160
    swatches.deltax = 60
    swatches.dxTextSpace = 10
    swatches.columnMaximum = 4
    items = [(colors.blue, name1), (colors.lightblue, name2)]
    swatches.colorNamePairs = items
    d.add(swatches, 'legend')
    return d
########   Now lets put everything together.   ########
# create a list and add the elements of our document (image, paragraphs, table, chart) to it
story = []
#define the style for our paragraph text
styles = getSampleStyleSheet()
styleN = styles['Normal']
#First add the Vizard Logo
imagePath = viz.res.getFullPath('lake3.jpg')
im = Image(imagePath, width=1*inch, height=1*inch)
im.hAlign = 'CENTER'
story.append(im)
#add the title
story.append(Paragraph("<strong>Results for Vizard Experiment</strong>",styleN))
story.append(Spacer(1,.25*inch))
#convert data to paragraph form and then add paragraphs
story.append(Paragraph(dataToParagraph(subject1, results1),styleN))
story.append(Paragraph(dataToParagraph(subject2, results2),styleN))
story.append(Spacer(1,.5*inch))
#add our table - first prepare data and then pass this to myTable function
tabledata = (
('', 'Trial 1', 'Trial 2', 'Trial 3','Trial 4','Trial 5'),
dataToTable(subject1, results1),
dataToTable(subject2, results2))
story.append(myTable(tabledata))
#add our barchart and legend
drawing = myBarChart([results1,results2])
drawing = myBarLegend(drawing,subject1,subject2)
drawing.hAlign = 'CENTER'
story.append(drawing)
#build our document with the list of flowables we put together
doc = SimpleDocTemplate('mydoc.pdf',pagesize = letter, topMargin=0)
doc.build(story)
