Vizard 8 » Reference » Graphical user interfaces (GUIs) » HTML and web browsers » HTML forms in a remote browser
8.3.1
In order to collect data from an HTML form displayed in a remote browser, a page containing HTML content needs to be registered with vizhtml's local HTTP server. A form submission event will get triggered once a form is submitted and data can be collected using a task or callback function.
The following commands register pages with HTML content:
Command
Description
vizhtml.registerFile(url,
                          filename,
                          directory=None)
Registers a page with the vizhtml server that uses an HTML file for content.
url: The path portion of the page's URL. See the server and URL section for further details about URLs.
filename: The name of the HTML file.
directory: The directory where page resources are saved.
vizhtml.registerCode(url,
                            code,
                            directory=None)
Registers a page with the vizhtml server that uses HTML code for content.
code: A string that contains HTML code.
In the following example, HTML code that contains a form is registered with the server. Once the form is submitted from a browser, it's data is collected in Vizard.
For testing on a local browser use 'localhost' or the loopback address:
http://localhost:8080/vizhtml/form_submit
http://127.0.0.1:8080/vizhtml/form_submit
For remote browsers replace computer name or IP address with the Vizard machine's name or address
http://computer name:8080/vizhtml/form_submit
http://IP Address:8080/vizhtml/form_submit
import viz
import vizhtml
code = """
<html>
<head>
    <title>vizhtml Form Submit Example</title>
</head>
<body>
<form name="the_form" method="post">
            <table>
                <tr>
                    <td>First Name</td>
                    <td><input type="text" name="first_name"></td>
                </tr>
                <tr>
                    <td>Last Name</td>
                    <td><input type="text" name="last_name"></td>
                </tr>
                <tr>
                    <td></td>
                    <td><input type="submit" value="Submit"></td>
                </tr>
            </table>
        </form>
</body>
</html>
vizhtml.registerCode('form_submit',code)
def HandleForm(e):
    print(e.first_name,e.last_name)
vizhtml.onFormSubmit(HandleForm)
Custom handlers
When an HTTP request (e.g. page request, resource request, form submission) arrives at vizhtml's HTTP server, it get's handled so the appropriate action is taken.
By registering your own handler with the server you can have perform custom actions when a request arrives. The handler will be passed a request object that provides information about the browser's request and methods to send content back to the browser.
The following command registers a handler with the server:
Command
Description
vizhtml.registerHandlerClass(url,
                                      handler_class
                                      directory=None)
Registers a custom handler class with the vizhtml server.
url: The path portion of the URL. See the server and URL section for further details about URLs.
handler_class: A custom handler class that extends the vizhtml.PageRequestHandler class.
The custom handler should inherit from vizhtml.PageRequestHandler and override it's handle_request method. This method is passed a request object that is an instance of vizhtml.VizardHTTPRequestHandler.
Note: The handle_request method is called from a separate thread than the main thread.
 VizardHTTPRequestHandler inherits from Python's BaseHTTPRequestHandler class and adds the following methods and attributes:
Attribute
Description
<VizardHTTPRequestHandler>.form_event
The form event if the request is from a form submission, otherwise None.
<VizardHTTPRequestHandler>.resource_path
The relative path of a resource request from custom page (e.g. images).
Method
Description
<VizardHTTPRequestHandler>.send_html_code(code)
Sends the specified HTML code to the browser.
<VizardHTTPRequestHandler>.send_html_file(filename)
Sends the specified HTML file to the browser.
<VizardHTTPRequestHandler>.send_local_resource(filename,
        mimetype=None)
Sends the specified resource file to the browser.
mimetype: If this is None it will be guessed from the filename. Otherwise it must be a 2-item tuple containing the HTTP content type and content encoding strings.
The example code below uses a custom handler to update content on a web page after a form submission. The data retrieved from the form's  text field is placed back into the page and Vizard's frame count is displayed.
http://localhost:8080/vizhtml/custom_handler
http://127.0.0.1:8080/vizhtml/custom_handler
http://computer name:8080/vizhtml/custom_handler
http://IP Address:8080/vizhtml/custom_handler
import cgi
import viz
import vizinfo
import vizhtml
# Display form submitted message on screen
info = vizinfo.InfoPanel('')
code = """
<html>
<head>
    <title>vizhtml Custom Handler Example</title>
</head>
<body onload="document.the_form.message.focus();">
<img src='ball.jpg'>
    <table>
        <tr>
            <td>Frame Number:</td>
            <td>{frame}</td>
        </tr>
        <tr>
            <td>Message:</td>
            <td><input type="text" name="message" value="{message}"></td>
        </tr>
        <tr>
            <td></td>
        </tr>
    </table>
</form>
</body>
</html>
class ExampleRequestHandler(vizhtml.PageRequestHandler):
    def handle_request(self,request):
        """@args vizhtml.VizardHTTPRequestHandler()"""
        # If request is for a resource (e.g. image), then let vizhtml handle it
        if request.resource_path:
            return
        # If form was submitted, put message back into page
        if request.form_event:
            message = cgi.escape(request.form_event.message,True)
            message = ''
        # Send html code with dynamic content
        request.send_html_code(code.format(frame=viz.getFrameNumber(),message=message))
vizhtml.registerHandlerClass('custom_handler',ExampleRequestHandler,directory='.')
def HandleForm(e):
    info.setText(e.message)
vizhtml introduction
HTML Forms in Vizard
HTML Forms in a remote browser
Collecting form data
Local HTTP server and URLs
WebSockets
