Vizard 8 » Reference » Stereo & Displays » Stereo Modes » Anaglyphic (red/cyan glasses)
8.3.1
Use this method to view stereoscopy with the use of red/cyan glasses. This can be presented to virtually any display device and works by drawing both left and right channel images simultaneously but color separated. This is not tied to a particular display device but rather requires red/cyan glasses.
Understanding Anaglyphic Stereo
Anaglyphs are one of the earliest methods devised to portray stereoscopic images with the least sophisticated hardware. No lenses or polarized filters are needed. Instead, all that is required to view an anaglyph is a red/cyan filter placed over the left and right eyes. The viewed image is built in a way that codes the imagery intended to be seen by the left eye as cyan and likewise red for the right. This allows one image to contain information intended to be seen almost exclusively by a single eye.
You can use this mode with any environments that you create in Vizard.
Implementing Anaglyphic Stereo
The following script illustrates all that is necessary to create a world in frame sequential stereo mode:
# The following illustrates how to start a graphics environment that renders anaglyphic stereo.
viz.go(viz.ANAGLYPHIC | viz.FULLSCREEN)
Once this mode is activated, you will need a pair of red/cyan glasses to view the resulting images.
See also
In this section:
Frame parallel
Frame sequential
Line interlaced
Other sections:
Elumens Dome
nVis HMDs
ACT Kern
Sensics
Fakespace Labs Wide5
iZ3D
Tridelity
Crescent
Sony HMDs
