Vizard 8 » Reference » Stereo & Displays » Display devices » Fakespace Labs Wide5
8.3.1
Vizard can drive this ultra wide field of view head-mounted display. To do so, you only need to copy & paste the code fragment shown below to your own program. For the tiling to function correctly, you must ensure that you have matched the tilt angles correctly as described in the user guide for your particular model.
In the code below, be sure to correctly set these parameters depending on your HMD:
In addition, you can optionally define the inter-pupillary separation (it is set to 0.06 by default).
import fakespace
fakespace.wide5(ipd=0.06,yaw=11.25,pitchN=10.0,pitchW=5.0)
You can optionally specify these values in your vizcore.cfg file by using the following option names:
Wide5 option name
Description
fakespace.wide5.ipd
Default IPD value
fakespace.wide5.yaw
Default yaw offset (degrees)
fakespace.wide5.pitchN
Default narrow pitch (degrees)
fakespace.wide5.pitchW
Default wide pitch (degrees)
See also
In this section:
Elumens Dome
nVis HMDs
ACT Kern
Sensics
iZ3D
Tridelity
Crescent
Sony HMDs
SteamVR HMDs
Oculus HMDs
Viulux HMDs
Other sections:
Frame parallel
Frame sequential
Line interlaced
Anaglyphic (red/cyan glasses)
