Vizard 8 » Reference » Clustering » Cluster callbacks
8.3.1
Cluster callbacks
The communication between the cluster master and clients is generally a one-way communication (i.e. the master sends commands to the clients to execute). However, there is limited functionality to have clients notify the master of certain input events (e.g. mouse, keyboard).
Registering callbacks
Cluster clients are capable of notifying the master of the following input events:
Cluster client events
viz.KEYDOWN_EVENT
viz.KEYUP_EVENT
viz.KEY_CHAR_EVENT
viz.MOUSEDOWN_EVENT
viz.MOUSEUP_EVENT
viz.MOUSEWHEEL_EVENT
viz.MOUSE_MOVE_EVENT
viz.DOUBLE_CLICK_EVENT
viz.BUTTON_EVENT
viz.SLIDER_EVENT
viz.LIST_EVENT
viz.WINDOW_SIZE_EVENT
To register a callback for a cluster client event, you must use the <viz>.callback command, and specify the cluster mask through the optional mask parameter. When the event is triggered on any of the specified client machines, the registered function will be called. You can determine which client triggered the event within the callback by using the <viz:cluster>.getClient command.
Here is an example that allows each client machine to change the background color by pressing the '1', '2', or '3' key:
COLORS = {'1':viz.RED,'2':viz.GREEN,'3':viz.BLUE}
def onKeyDown(key):
    if key in COLORS:
        # The client that triggered the event
        client = viz.cluster.getClient()
        # Set color only on client machine
        with viz.cluster.MaskedContext(client):
            viz.clearcolor(COLORS[key])
viz.callback(viz.KEYDOWN_EVENT, onKeyDown, mask=viz.ALLCLIENTS)
See also
In this section:
Cluster basics
Connecting your cluster
Collaboration
Cluster masks
Handling project resources
Clustering Command Table
Other sections:
Vizcave
Networking basics
