Vizard 8 » Reference » Flow control » Actions » Creating your own actions
8.3.1
Creating Your Own Actions
Actions are useful Vizard constructs that help organize the behavior of nodes and views.  The Vizard API makes it easy to create custom actions to handle your application specific tasks.
Actions are classes that inherit from viz.ActionClass.  Actions then have a variety of methods they can override to provide functionality.  Heres a list:
begin(self,object)
update(self,elapsed,object)
pause(self,state)
end(self,object)
Action classes can also check there current execution state with these methods:
finished(self)
paused(self)
Code Examples
Here is how the spin action is implemented:
class VizSpinAction(viz.ActionClass):
    def begin(self,object):
        self.data = self._actiondata_.data
        self.elapsed = 0
        self.duration = self.data[4]
        self.totalAngle = 0
        self.finalAngle = self.duration * self.data[3]
    def update(self,elapsed,object):
        self.elapsed += elapsed
        #If spinning for a finite duration, check if time has passed
        if self.duration > 0.0 and self.elapsed > self.duration:
            self._overtime_ = self.elapsed - self.duration
            object.setAxisAngle(self.data[0],self.data[1],self.data[2],self.finalAngle-self.totalAngle,viz.REL_LOCAL)
            self.end(object)
            inc = self.data[3]*elapsed
            self.totalAngle += inc
            object.setAxisAngle(self.data[0],self.data[1],self.data[2],inc,viz.REL_LOCAL)
    def spin(x,y,z,speed,dur=viz.FOREVER):
        bla = viz.ActionData()
        bla.data =[x,y,z,speed,dur]
        bla.actionclass=VizSpinAction
        return bla
node = viz.add('logo.wrl')
node.addAction(vizact.spin(0,1,0,90))
Here is an action that rotates an avatar's head to watch a node:
class WatchNodeAction(viz.ActionClass):
    """Makes avatar head follow node object around"""
        """Called once when action starts"""
        #Get the node the avatar should look at
        self.nodeToLookAt = self._actiondata_.data[0]
        #Get time the avatar will look at object
        self.duration = self._actiondata_.data[1]
        self.headBone = self._actiondata_.data[2]
        self.blendIn = self._actiondata_.data[3]
        self.timeElapsed = 0
        #Get the head bone and lock it
        self.head = object.getBone(self.headBone)
        self.head.lock()
        self.startQuat = self.head.getQuat()
        """Called every frame to update action"""
        self.timeElapsed += elapsed #time avatar has looked at node
        p = self.timeElapsed / self.blendIn
        #If looking for a finite duration, check if time has passed
        if self.duration > 0.0 and self.timeElapsed > self.duration:
            #duration passed, end action
            self.head.lookAt( self.nodeToLookAt.getPosition(), 0, viz.AVATAR_WORLD )
            self.end(object) #End the action and clear it from the action queue
        elif p < 1.0:
            #blend in head look
            targetQuat = self.head.getQuat()
            nextQuad = vizmat.slerp(self.startQuat,targetQuat,p)
            self.head.setQuat(nextQuad)
            #Done with blend in, just look at node
            self.head.lookAt(self.nodeToLookAt.getPosition(), 0, viz.AVATAR_WORLD)
    def end(self,object):
        if self.head:
            self.head.unlock()
        viz.ActionClass.end(self,object)
#Function to construct the action instance
def watchNode( nodeToLookAt, duration = viz.FOREVER, headBone = 'Bip01 Head', blendIn = .2 ):
    action = viz.ActionData()
    action.data = [ nodeToLookAt, duration, headBone, blendIn ]
    action.actionclass = WatchNodeAction
    return action
viz.MainView.setPosition( 0, 0, 0 )
#Setup ball for the avatar to track
ball = viz.addChild('beachball.osgb',scale=[0.2]*3)
path = viz.addAnimationPath()
points = [ [0,0,1], [-0.3,0,1], [0,0.3,1], [0.3,0,1], [0,-0.3,1], [0,0,1.5], [0,0,1] ]
for x,pos in enumerate(points):
    path.addControlPoint(0.5*x,pos=pos)
path.setLoopMode(viz.LOOP)
path.play()
viz.link(path,ball)
male = viz.add( 'vcc_male.cfg' )
male.setPosition( 0, -1.5, 2 )
male.setEuler( 180, 0, 0 )
male.idlepose(-1)
#Apply the action to the avatar
male.addAction( watchNode(ball, viz.FOREVER) )
def endHeadWatch():
    #blend head to neutral orientation
    head = male.getBone('Bip01 Head')
    headQuat = head.getQuat(viz.AVATAR_LOCAL)
    male.endAction()
    head.lock()
    head.setQuat(headQuat, viz.AVATAR_LOCAL)
    male.addAction( vizact.headto( 0,0,0, 20, bone = 'Bip01 Head'), 1 )
vizact.onkeydown(' ',endHeadWatch)
See also
In this section:
Action Basics
Action synchronization and management
Sequences
Dynamic parameters
Node commands as actions
Actions command table
Other sections:
Tutorial: Using actions
Task basics
Director basics
Timer basics
Animation path basics
Event Basics
