Vizard 8 » Reference » Appearance & Texturing » Environment mapping
8.3.1
Environment Mapping
Environment mapping is a technique used to simulate surface reflection. The basic principle is that if you were to look at a reflective object in a room, you would see the walls, the floor, and other objects in the room reflected off of the object. When building your Vizard scene you might want to employ environment mapping to produce added realism.
To use environment mapping in Vizard, you simply have to add the appropriate texture map, apply the texture to a node 3D object, and then add the viz.ENVIRONMENT_MAP flag to <node3d>.appearance as in the following example:
env = viz.addEnvironmentMap('sky.jpg')
logo = viz.addChild('logo.ive')
logo.setPosition([0,1,4])
logo.texture(env)
logo.appearance(viz.ENVIRONMENT_MAP)
See also
In this section:
Appearance & texturing basics
Texture wrapping
Multi-texturing
Texture appearance and filtering
Texture types
Texture matrix
Visibility
Draw order & Z offsetting
Projecting textures
Appearance & texturing command table
Other sections:
Tutorial: Environmental mapping
Example scripts:
Environment mapping
