Vizard 8 » Reference » Appearance & Texturing » Texture appearance and filtering
8.3.1
Texture map appearance
To change the texture map appearance of your 3D object, modify it by adding <node3d>.appearance to your script, replacing <node3d> with your 3D object, and one of the following flags:
Texture modifier
Flag
Automatic texture coordinate generation for reflective surfaces.
viz.TEXGEN
Linear and mipmap filtering for texture magnification and minification.
viz.TEXMIPMAP
Don't perform any linear or mipmap filtering.
viz.TEXNEAREST
Force modulation of texture with any scene lights and the surfaces underlying material color properties.
viz.TEXMODULATE
Display the exact bitmap as the surface texture.
viz.TEXDECAL
Allow texture coordinates outside [0,1] range.
viz.TEXREPEAT
Clamp texture coordinates to [0,1] range.
viz.TEXCLAMP
Texture filtering
Vizard uses OpenGL filtering modes for textures. The filter mode defines how a texture pixel is calculated. There are two filter modes, the minification filter and magnification filter. The minification filter is used when the size of the texture on screen is smaller than the actual texture. The magnification filter is used when the size of the texture on screen is larger than the actual texture. Here is a list of all the possible filter modes:
Texture filter flag
Description
viz.LINEAR
Use linear interpolation between the 4 nearest texture pixels. (Default for magnification filter).
viz.LINEAR_MIPMAP_LINEAR
Calculates linear texture pixel value from two nearest mipmaps and linearly interpolates between those two values. (Default for minification filter) (Only available for minification filter).
viz.LINEAR_MIPMAP_NEAREST
Uses the linearly interpolated texture pixel from the nearest mipmap. (Only available for minification filter).
viz.NEAREST
Use the nearest texture pixel.
viz.NEAREST_MIPMAP_LINEAR
Uses the nearest texture pixel from the two nearest mipmaps and linearly interpolates between them. (Only available for minification filter).
viz.NEAREST_MIPMAP_NEAREST
Uses the nearest texture pixel from the nearest mipmap. (Only available for minification filter).
Using linear filtering makes the texture look smoother, that is why Vizard uses it as the default. Here is sample code to set the filter mode of a texture to viz.NEAREST:
texture.filter(viz.MIN_FILTER,viz.NEAREST)
texture.filter(viz.MAG_FILTER,viz.NEAREST)
See also
In this section:
Appearance & texturing basics
Texture wrapping
Multi-texturing
Environment mapping
Texture types
Texture matrix
Visibility
Draw order & Z offsetting
Projecting textures
Appearance & texturing command table
Other sections:
Tutorial: Applying Textures
Example scripts:
Alpha map
