Vizard 8 » Reference » Appearance & Texturing » Texture types
8.3.1
Texture types
If you are familiar with OpenGL you will notice that Vizard has exposed some of the basic texture options to the user. When adding textures you can specify which type of OpenGL texture to create. The most common and default type is a 2D texture. Here is a list of the available texture types:
Texture type flag
Description
viz.TEX_1D
One dimensional texture
viz.TEX_2D
Two dimensional texture
viz.TEX_3D
Three dimensional texture
viz.TEX_CUBE
Cube mapped texture. Composed of 6 textures that represent each side of a cube. Most commonly used for environment mapping.
viz.TEX_RECT
Texture rectangle. Same as a 2D texture except that texture coordinates are in pixel values instead of 0 to 1. Does not require image size to be a power of 2.
For instance, if you wanted to create a Texture Rectangle you would use the following code:
texture = viz.add('myfile.jpeg',viz.TEX_RECT)
To create a cubemap you would do something similar to this:
texture = viz.add('right.jpg',TEX_CUBE)
texture.load('left.jpg',NEGATIVE_X)
texture.load('down.jpg',NEGATIVE_Y)
texture.load('up.jpg',POSITIVE_Y)
texture.load('front.jpg',POSITIVE_Z)
texture.load('back.jpg',NEGATIVE_Z)
Loading all 6 textures for a cube map can become quite tedious, that is why Vizard has a built-in method for loading a cube map. Let's say you have the following textures that represent a cube map:
You could use the following code to load the cube map:
texture = viz.addEnvironmentMap('sky.jpg')
Vizard will automatically add the _posx, _negx, and so on to the end of the texture name and load each into a cube map.
See also
In this section:
Appearance & texturing basics
Texture wrapping
Multi-texturing
Environment mapping
Texture appearance and filtering
Texture matrix
Visibility
Draw order & Z offsetting
Projecting textures
Appearance & texturing command table
Other sections:
Tutorial: 360 panoramas
