Vizard 7 » Reference » Shaders » Post-Process Effects » Color effects
7.4
Color effects
The vizfx.postprocess.color library is a collection of effects that perform various color adjustments.
Grayscale
Convert the colors to grayscale.
import vizfx.postprocess
from vizfx.postprocess.color import GrayscaleEffect
effect = GrayscaleEffect()
vizfx.postprocess.addEffect(effect)
Sepia
Convert the colors to a sepia tone.
from vizfx.postprocess.color import SepiaToneEffect
effect = SepiaToneEffect()
Bleach Bypass
Applies a bleach bypass effect on the image, which simulates the skipping of the bleaching function during the processing of color film.
from vizfx.postprocess.color import BleachBypassEffect
effect = BleachBypassEffect()
Invert
Invert the colors.
from vizfx.postprocess.color import InvertColorEffect
effect = InvertColorEffect()
Color Offset
Apply an offset to each color channel.
Constructor
Description
ColorOffsetEffect(
    red = 0.0,
    green = 0.0,
    blue = 0.0
Create the color offset effect with the initial red, green, and blue offset values.
Method
Description
<effect>.setRedOffset(offset)
Set the offset for the red channel.
<effect>.getRedOffset()
Get the offset for the red channel.
<effect>.setGreenOffset(offset)
Set the offset for the green channel.
<effect>.getGreenOffset()
Get the offset for the green channel.
<effect>.setBlueOffset(offset)
Set the offset for the blue channel.
<effect>.getBlueOffset()
Get the offset for the blue channel.
<effect>.setColorOffset(offset)
Set the offset for the red, green, and blue channels using the specified 3-item list.
<effect>.getColorOffset()
Get the offset for the red, green, and blue channels.
This effect can be registered with vizconfig.
from vizfx.postprocess.color import ColorOffsetEffect
effect = ColorOffsetEffect()
effect.setColorOffset([0.5,0.5,-0.2])
Color Scale
Apply a scale factor to each color channel.
Constructor
Description
ColorScaleEffect(
    red = 1.0,
    green = 1.0,
    blue = 1.0
Create the color scale effect with the initial red, green, and blue scale factors.
Method
Description
<effect>.setRedScale(scale)
Set the scale factor for the red channel.
<effect>.getRedScale()
Get the scale factor for the red channel.
<effect>.setGreenScale(scale)
Set the scale factor for the green channel.
<effect>.getGreenScale()
Get the scale factor for the green channel.
<effect>.setBlueScale(scale)
Set the scale factor for the blue channel.
<effect>.getBlueScale()
Get the scale factor for the blue channel.
<effect>.setColorScale(scale)
Set the scale factor for the red, green, and blue channels using the specified 3-item list.
<effect>.getColorScale()
Get the scale factor for the red, green, and blue channels.
from vizfx.postprocess.color import ColorScaleEffect
effect = ColorScaleEffect()
effect.setRedScale(2.0)
effect.setGreenScale(1.5)
Color Correction
Apply color correction to the image similar to the "curves" tool found in many popular image editing programs (e.g. Photoshop, Paint.NET).
The effect uses a 256 x 1 lookup texture to perform the color correction. You can use the following steps to create a lookup texture:
  1. Open the template lookup texture (template.png located in the [Vizard]/resources/color_correction folder) into your image editing program.
  2. Use the "Curves" tool to create the desired color correction and apply it to the image.
  3. Save the image to a new file (png format is recommended).
Lookup texture used for the image above:
Constructor
Description
ColorCorrectionEffect(texture)
Create the color correction effect using the specified lookup texture.
from vizfx.postprocess.color import ColorCorrectionEffect
texture = viz.addTexture('color_correction/xpro.png')
effect = ColorCorrectionEffect(texture)
Brightness
Control the brightness of the image.
Constructor
Description
BrightnessEffect(brightness = 0.0)
Create the brightness effect with the initial brightness value. The brightness value can range from -1 to 1.
Method
Description
<effect>.setBrightness(value)
Set the brightness value.
<effect>.getBrightness()
Get the brightness value.
from vizfx.postprocess.color import BrightnessEffect
effect = BrightnessEffect(0.5)
Contrast
Control the contrast of the image.
Constructor
Description
ContrastEffect(contrast = 0.0)
Create the contrast effect with the initial contrast value. The contrast value can range from -1 to 1.
Method
Description
<effect>.setContrast(value)
Set the contrast value.
<effect>.getContrast()
Get the contrast value.
from vizfx.postprocess.color import ContrastEffect
effect = ContrastEffect(0.3)
Exposure
Control the exposure of the image.
Constructor
Description
ExposureEffect(exposure= 0.0)
Create the exposure effect with the initial exposure value.
Method
Description
<effect>.setExposure(value)
Set the exposure value. A positive value will over-expose the image. A negative value will under-expose the image.
<effect>.getExposure()
Get the exposure value.
from vizfx.postprocess.color import ExposureEffect
effect = ExposureEffect(1.0)
Hue
Adjust the image hue.
Constructor
Description
HueEffect(hue= 0.0)
Create the hue effect with the initial hue value.
Method
Description
<effect>.setHue(value)
Set the hue value. The value ranges from -1 to 1.
<effect>.getHue()
Get the hue value.
from vizfx.postprocess.color import HueEffect
effect = HueEffect(0.2)
Saturation
Adjust the image saturation.
Constructor
Description
SaturationEffect(saturation= 0.0)
Create the saturation effect with the initial saturation value.
Method
Description
<effect>.setSaturation(value)
Set the saturation value. The value ranges from -1 to 1. Positive values saturate, and negative values desaturate.
<effect>.getSaturation()
Get the saturation value.
from vizfx.postprocess.color import SaturationEffect
effect = SaturationEffect(0.5)
Vibrance
Adjust image vibrance by modifying saturation of desaturated colors.
Constructor
Description
VibranceEffect(vibrance= 0.0)
Create the vibrance effect with the initial vibrance value.
Method
Description
<effect>.setVibrance(value)
Set the vibrance value. The value ranges from -1 to 1. Positive values add vibrance, and negative values remove vibrance.
<effect>.getVibrance()
Get the vibrance value.
from vizfx.postprocess.color import VibranceEffect
effect = VibranceEffect(1.0)
Gamma Correction
Applies gamma correction to the image.
Constructor
Description
GammaCorrectionEffect(gamma = 1.0)
Create the gamma correction effect with the initial gamma value. Most displays and graphics cards support gamma correction, so this effect is usually unnecessary. Most displays have a gamma of approximately 2.2.
Method
Description
<effect>.setGamma(value)
Set the gamma value.
<effect>.getGamma()
Get the gamma value.
from vizfx.postprocess.color import GammaCorrectionEffect
effect = GammaCorrectionEffect(2.2)
Posterize
Posterizes the image (reduces number of increments in the color values).
Constructor
Description
PosterizeEffect(increments = 255)
Create the posterize effect with the initial number of color value increments.
Method
Description
<effect>.setIncrements(value)
Set the number of color value increments.
<effect>.getIncrements()
Get the number of color value increments.
from vizfx.postprocess.color import PosterizeEffect
effect = PosterizeEffect(6)
Post-Process Basics
Color Effects
Distort Effects
Blur Effects
Transform Effects
Composite Effects
