Vizard 8 » Reference » Shaders » Post-Process Effects » Distort effects
8.3.1
Distort effects
The vizfx.postprocess.distort library is a collection of effects that perform various distortions on the rendered image by modifying the texture coordinates of each pixel.
Pincushion
Applies a pincushion/barrel distortion on the image.
Constructor
Description
PincushionEffect(
    k1 = 0.0,
    scaleToFit = True
Create the pincushion effect with the initial k1 factor and scaleToFit setting.
Method
Description
<effect>.setK1(value)
Set the k1 value of the distortion. A positive value results in a barrel distortion, a negative value results in a pincushion distortion.
<effect>.getK1()
Get the k1 distortion value.
<effect>.setScaleToFit(value)
Set whether distortion is scaled to fit resolution of output image.
<effect>.getScaleToFit()
Get scale to fit setting.
This effect can be registered with vizconfig.
import vizfx.postprocess
from vizfx.postprocess.distort import PincushionEffect
effect = PincushionEffect(0.5)
vizfx.postprocess.addEffect(effect)
Pixelate
Pixelates the image.
Constructor
Description
PixelateEffect(pixelSize = (1,1))
Create the pixelate effect with the initial pixelSize.
Method
Description
<effect>.setPixelSize(size)
Set the [width,height] pixel size. This is the number of actual pixels that will make up the virtual pixel.
<effect>.getPixelSize()
Get the [width,height] pixel size.
from vizfx.postprocess.distort import PixelateEffect
effect = PixelateEffect([10,10])
Bulge
Bulges the image.
Constructor
Description
BulgeEffect(
    bulge = 0.0,
    radius = 0.5,
    center = (0.5,0.5)
Create the bulge effect with the initial bulge factor, radius, and center.
Method
Description
<effect>.setBulge(value)
Set the bulge factor. Typically ranges from -1 to 1. Positive value bulges the image outwards, negative value bulges the image inward.
<effect>.getBulge()
Get the bulge factor.
<effect>.setRadius(radius)
Set the bulge radius in normalized (0-1) image units.
<effect>.getRadius()
Get the bulge radius in normalized (0-1) image units.
<effect>.setCenter(center)
Set the bulge [x,y] center in normalized (0-1) image units.
<effect>.getCenter()
Get the bulge [x,y] center in normalized (0-1) image units.
from vizfx.postprocess.distort import BulgeEffect
effect = BulgeEffect(0.5)
Twist
Twists the image.
Constructor
Description
TwistEffect(
    twist = 0.0,
    radius = 0.5,
    center = (0.5,0.5)
Create the twist effect with the initial twist angle, radius, and center.
Method
Description
<effect>.setTwist(twist)
Set the twist angle in degrees. Positive value twists the image clockwise, negative value twists the image counter-clockwise.
<effect>.getTwist()
Get the twist angle in degrees.
Set the twist radius in normalized (0-1) image units.
Get the twist radius in normalized (0-1) image units.
Set the twist [x,y] center in normalized (0-1) image units.
Get the twist [x,y] center in normalized (0-1) image units.
from vizfx.postprocess.distort import TwistEffect
effect = TwistEffect(180)
Wave
Applies a sine wave to the image.
Constructor
Description
WaveEffect(
    amplitude = 0.0,
    period = 1.0,
    offset = 0.0,
    angle = 0.0,
    repeat = False
Create the wave effect with the initial parameters.
Method
Description
<effect>.setAmplitude(twist)
Set the amplitude of the wave in normalized (0-1) image units.
<effect>.getAmplitude()
Get the amplitude of the wave in normalized (0-1) image units.
<effect>.setPeriod(radius)
Set the period of the wave in normalized (0-1) image units.
<effect>.getPeriod()
Get the period of the wave in normalized (0-1) image units.
<effect>.setOffset(center)
Set the offset of the wave along the horizontal axis in normalized (0-1) image units.
<effect>.getOffset()
Get the offset of the wave along the horizontal axis in normalized (0-1) image units.
<effect>.setAngle(value)
Set the angle of the vertical axis of the wave, in degrees. 0 is upward, and positive angles go clockwise.
<effect>.getAngle()
Get the angle of the vertical axis of the wave, in degrees.
<effect>.setRepeat(value)
Set whether to repeat the image when UV coordinates are outside (0-1) range.
<effect>.getRepeat()
Get whether to repeat the image when UV coordinates are outside (0-1) range.
from vizfx.postprocess.distort import WaveEffect
effect = WaveEffect(amplitude=0.05, period=3.0)
Post-Process Basics
Color Effects
Distort Effects
Blur Effects
Transform Effects
Composite Effects
