Vizard 8 » Reference » Proximity Sensors » vizproximity events
8.3.1
vizproximity events
The following events are generated by a manager when a target enters/exits a sensor:
Event
vizproximity.ENTER_PROXIMITY_EVENT
vizproximity.EXIT_PROXIMITY_EVENT
Both events provide a single event structure e with the following attributes:
Attribute
Description
sensor
The sensor that was activated.
target
The activating target.
manager
The manager for the sensor/target involved.
There are two ways to work with these events:
Register callback functions with a proximity manager
Use the following methods on the Manager object to register callback functions for proximity events:
Method
Description
<Manager>.onEnter(sensor,
                           func,
                           *args,
                           **kw)
Call the specified function when a target enters the proximity sensor. If sensor is not specified then all sensors will be allowed.
<Manager>.onExit(sensor,
                         func,
                         *args,
                         **kw)
Call the specified function when a target exits the proximity sensor. If sensor is not specified then all sensors will be allowed.
The following code shows how to register callback functions for proximity events:
def EnterProximity(e):
    """@args vizproximity.ProximityEvent()"""
    print('entered',e.sensor)
def ExitProximity(e):
    print('exited',e.sensor)
manager.onEnter(None,EnterProximity)
manager.onExit(None,ExitProximity)
Wait for proximity events in a task function
Task functions, from the viztask library, are useful for controlling program flow. Use the following commands to create viztask conditions that wait for proximity events:
Command
Description
vizproximity.waitEnter(sensor,
                              target,
                              manager)
viztask condition that waits for a proximity sensor enter event.
sensor - A Sensor object, list of Sensor objects, or None to allow any sensor
target - A Target object, list of Target objects, or None to allow any target
manager - A Manager object, list of Manager objects, or None to allow any manager
vizproximity.waitExit(sensor,
                            target,
                            manager)
viztask condition that waits for a proximity sensor exit event.
The following code shows to wait for a proximity event:
def proximityTask():
    #Add walk action to avatar when user gets close
    yield vizproximity.waitEnter(avatarSensor)
    avatar.runAction(walk)
viztask.schedule(proximityTask())
vizproximity introduction
vizproximity sensor
vizproximity target
vizproximity manager
vizproximity events
