Vizard 8 » Reference » Proximity Sensors » vizproximity target
8.3.1
vizproximity target
A proximity target is the object that is detected by proximity sensors. The following command creates a Target object:
Command
Description
vizproximity.Target(source)
Create a proximity target.
The target position is determined by the specified source object (e.g. node, view, tracker, bone, matrix)
The following methods are available on the Target object:
Method
Description
<Target>.getPosition()
Get current position of target.
<Target>.getSource()
Return the source object of the target.
<Target>.getSourceObject()
Return the underlying object of the target source (e.g. node, view, bone, etc..).
Example
#Add main viewpoint as proximity target
target = vizproximity.Target(viz.MainView)
vizproximity introduction
vizproximity sensor
vizproximity target
vizproximity manager
vizproximity events
