Vizard 8 » Reference » Viewpoints & Windows » Viewpoint & Window basics
8.3.1
Viewpoint & Window Basics
3D scenes are always viewed from a point in space and from a particular orientation. In Vizard, this point is called the "view" or "viewpoint". The viewpoint in Vizard is similar to what other programs would call the camera. When you navigate through a world using a mouse, you're simply moving the position and orientation of your viewpoint. While Vizard provides a default viewpoint, you can add multiple viewpoints.
Worlds are rendered in a window. A window can be linked to one viewpoint, or it can toggle back and forth between a number of different viewpoints. When you run a Vizard script, you automatically create the main window. This window, however, can have a number of different sub-windows. Windows have their own set of parameters which determine the world's rendering.
For more details, check out the section on viewpoints and the section on windows.
Grabbing and moving the main viewpoint
Use viz.MainView to grab the main view. Once you've got a handle on the main view (or created a new view) you can change it with any of the commands in the <viewpoint> method.  Check out the section on Views to get more specific information.
viz.add('court.ive')
#Grab the main view.
view = viz.MainView
#Use spinto to rotate it back and forth.
vizact.onkeydown( viz.KEY_LEFT, view.runAction, vizact.spinTo(euler=[-90,0,0], time=3) )
vizact.onkeydown( viz.KEY_RIGHT, view.runAction, vizact.spinTo(euler=[90,0,0], time=3) )
Grabbing and changing the main window
Use viz.MainWindow to grab the main window. Once you've got a handle on the main window (or created a sub-window) you can change it with any of the commands in the <window> class.  Check out the section on windows to get more specific information.
#Grab the main window.
window = viz.MainWindow
#Change its background color.
window.clearcolor( 1,0,0)
Adding an additional view with its own window
To create an additional window or view, use viz.addWindow and viz.addView, and then assign the view to the window with the <window>.setView command.
import viz
viz.addChild('court.ive')
#Add a new view.
subView = viz.addView()
#Add a new window.
subWindow = viz.addWindow()
#Set the size and position of the window.
subWindow.setSize([0.5,0.5])
subWindow.setPosition([0,1])
#Assign the new view to the new window.
subWindow.setView( subView )
#Add some rotation actions to the view.
vizact.onkeydown( viz.KEY_LEFT, subView.runAction, vizact.spinTo(euler=[-90,0,0], time=3) )
vizact.onkeydown( viz.KEY_RIGHT, subView.runAction, vizact.spinTo(euler=[90,0,0], time=3) )
See also
In this section:
Perspective rendering
Orthographic lenses
Viewpoint basics
Window basics
Viewpoints & windows command tables
Other sections:
Action Basics
Animation path basics
Application window basics
Example scripts:
Viewpoint camera control
Viewpoint animation
Viewpoint collision
Window views
