Reference: Physics
Physics Command Table
<viz:phys>.command
<viz:phys>.disable
<viz:phys>.enable
<viz:phys>.getEnabled
<viz:phys>.getGravity
<viz:phys>.intersectLine
<viz:phys>.intersectNode
<viz:phys>.setEnabled
<viz:phys>.setGravity
<VizPhysicsShape>.command
<VizPhysicsShape>.getBounce
<VizPhysicsShape>.getDensity
<VizPhysicsShape>.getFriction
<VizPhysicsShape>.getHardness
<VizPhysicsShape>.getType
<VizPhysicsShape>.setBounce
<VizPhysicsShape>.setDensity
<VizPhysicsShape>.setFriction
<VizPhysicsShape>.setHardness
NOTE: The following  commands have no effect if physics is not defined on the node.
<node3d>.applyForce
<node3d>.applyTorque
<node3d>.collideBox
<node3d>.collideCapsule
<node3d>.collideCopy
<node3d>.collideMesh
<node3d>.collideNone
<node3d>.collidePlane
<node3d>.collideSphere
<node3d>.commandPhysics
<node3d>.getAngularVelocity
<node3d>.getVelocity
<node3d>.setAngularVelocity
<node3d>.setVelocity
See also
In this section:
Physics basics
Physics Shapes - In depth discussion of the collide methods.
Forces - More detail on applyForce and applyTorque.
Joints - In depth overview of the joint types.
Motors - In depth explanation of how each motor works with each joint.
Other sections:
Tutorial: Physics
Event Reference
Example scripts:
Basic physics
Tracking an object
Collision plane
Callbacks & complex shapes
Forces & materials
