Vizard 8 » Reference » Graphical user interfaces (GUIs) » GUI elements » GUI appearance
8.3.1
GUI appearance
Adding textures to GUI elements
To set the texture that appears when a button or checkbox is selected or unselected, use <button or checkbox>.downpicture( <texture> ) or <button or checkbox>.uppicture(<texture>), respectively. You can also apply a texture to the tick or bar on a slider.
#Add a slider.
mySlider = viz.addSlider()
mySlider.setPosition(.5,.25)
mySlider.setTickSize(4,3)
#Give the tick a new texture.
mySlider.tickpicture('vizinfo.tif')
#Add a checkbox.
myCheckBox = viz.addCheckbox()
myCheckBox.setPosition(.5,.75)
#Give it textures for when it's selected and unselected.
myCheckBox.uppicture('play.tif')
myCheckBox.downpicture('pause.tif')
Fonts
To change the font of any of your GUI elements, just use <GUI element>.font(<font filename>. Vizard will look inside the Windows/Font directory when setting a font. You can browse that directory to see what fonts are available on your system.
#Add a progress bar and choose its font.
myProgressBar = viz.addProgressBar('How is it going?')
myProgressBar.setPosition(.5,.5)
myProgressBar.font('Times New Roman')
Changing the color themes
To change the colors of text, background, and borders of GUIs, set their themes. This works for certain GUI elements (progress bars and droplists) and GUI containters (vizmenu, vizdlg, and vizinfo). The themeExample.py script (File > Quick Open > type: themeExample) shows how changing various theme properties affects a menu and info panel.
See also
In this section:
User interface basics
GUI elements
Getting data from GUI elements
GUI appearance
vizinfo
vizmenu
vizinput
vizdlg
vizconfig
viztip
Displaying HTML
GUI command table
Other sections:
Event Basics
Action basics
Text node basics
Example scripts:
vizInfo
vizMenu
Prompt
