Vizard 8 » Reference » Graphical user interfaces (GUIs) » viztip
8.3.1
viztip
The viztip library allows you to assign a tooltip attribute to any node object that contains the tooltip text. Once you create an instance of the viztip.ToolTip object, it will automatically display an on-screen tooltip when the mouse is over the node. The following example demonstrates this:
viz.add('tut_ground.wrl')
#Create models with tooltip text
ball1 = viz.add('ball.wrl',pos=(-2,1,5))
ball1.tooltip = 'Ball 1'
ball2 = viz.add('ball.wrl',pos=(0,1,5))
ball2.tooltip = 'Ball 2'
ball3 = viz.add('ball.wrl',pos=(2,1,5))
ball3.tooltip = 'Ball 3'
#Create a tool tip object
import viztip
tip = viztip.ToolTip()
Methods and Events
A number of methods are available on the Tooltip object. These control properties such as the time for the Tooltip to appear, whether it tracks the mouse position, it's visibility, and more. Events generated after a Tooltip object have been created include the viztip.TOOLTIP_BEGIN_EVENT and viztip.TOOLTIP_END_EVENT:
ball = viz.add('ball.wrl',pos=(0,1.8,2))
ball.tooltip = 'Ball'
import viztip
#set initial tooltip message and position
tip.message('Move the cursor over the ball')
tip.translate(300,50)
#action to add when mouse is over a tooltip object
spin = vizact.spin(0,1,0,45)
#handle toolpit events
def beginTip(e):
    e.node.addAction(spin)
viz.callback(viztip.TOOLTIP_BEGIN_EVENT,beginTip)
def endTip(e):
    e.node.endAction()
viz.callback(viztip.TOOLTIP_END_EVENT,endTip)
See also
In this section:
User interface basics
GUI elements
Getting data from GUI elements
GUI appearance
vizinfo
vizmenu
vizinput
vizdlg
vizconfig
viztip
Displaying HTML
GUI command table
Other sections:
Event Basics
Action basics
Text node basics
Example scripts:
vizInfo
vizMenu
Prompt
