Vizard 8 » Reference » Graphical user interfaces (GUIs) » GUI elements » Getting data from GUI elements
8.3.1
To pull user input from buttons, boxes and sliders, you can call them directly or set up a callback that gets triggered by new input.
Getting data from a buttons, checkboxes and sliders
Use <GUI element>.get() to get the data from a button, check box  or slider.
If you want to know if the user is currently moving the tick on a slider, use <slider>.dragging(). If the user is dragging the tick, the command will return a '1'.
data = mySlider.get() #Get the tick location.
isDragging = mySlider.dragging() #Is the tick dragging?
Getting data from a text boxes
The <GUI element>.get() command will give you the typed input from a textbox. You can also get the cursor location in the textbox using <text box>.getCursorPos().
myTextBox = viz.addTextbox()
myTextBox.get() #Get the text in the box.
myTextBox.getCursorPos() #Get the position of the cursor.
Getting data from droplists
Use <droplist>.getSelection() to get the index of the current selection on the droplist. Note: since this command will only give you the current index, you can use <droplist>.getItems() to find out the whole array of items and then use the index to pick out the value of the selected item.
#Find the index of the current selection.
drop.getSelection()
#Find the selection itself.
drop.getItems()[ drop.getSelection() ]
Setting up a GUI callback
The action library has methods of registering callback functions for GUI callback events. The commands <vizact>.onbuttondown, <vizact>.onbuttonup, <vizact>.onslider, <vizact>.onlist, and <vizact>.ontextbox will handle the following events.
#Add and position a slider and progress bar.
mySlider = viz.addSlider()
myProgressBar = viz.addProgressBar('How much?')
mySlider.setPosition(.5,.5)
myProgressBar.setPosition(.5,.25)
#Create functions to handle slider events
def sliderChanged(pos):
    print('mySlider is at ' + str(pos))
vizact.onslider(mySlider,sliderChanged)
def progressBarChanged(pos):
    print('myProgressBar is at ' + str(pos))
vizact.onslider(myProgressBar,progressBarChanged)
See also
In this section:
User interface basics
GUI elements
GUI appearance
vizinfo
vizmenu
vizinput
vizdlg
vizconfig
viztip
Displaying HTML
GUI command table
Other sections:
Event Basics
Action basics
Text node basics
Example scripts:
vizInfo
vizMenu
Prompt
