Vizard 8 » The Vizard IDE » Searching and navigation » Navigate backward/forward
8.3.1
The Navigate Backward/Forward feature (found in the View menu or using the Alt + Left/Right shortcuts) can be used after performing an operation that jumps the cursor to a new location. The following table lists the operations that affect the navigation history:
Operation
Description/Location
Go to find result
All find operations in the Find > Find and replace sub-menu.
Go to line
Going to a line using the Edit > Go To Line option.
Go to definition
Script context menu option available when right clicking an object name.
Go to code browser definition
Double clicking an item in the code browser pane.
Go to task item
Double clicking a task item in the task list.
Go to traceback location
Clicking a Python traceback location in the interactive window.
Run debugger
This applies when a breakpoint has been reached, stepping code, and opening a file through the call stack pane.
Open file
Files opened through the File > Open option and files dragged into the editor.
See also
Find and Replace
Go To Definition
Code Browser
Task List
Interactive Window
Debugger
